engine stalls
Old Dec 14, 2010 | 12:35 PM
evo_gremlin's Avatar
really something that simple would cause it to randomly just die and then restart?
Old Dec 14, 2010 | 12:39 PM
L@Ncer06's Avatar
Originally Posted by downshift411
it looks like your alternator isn't charging. Your draining your battery each time you start it up like that. For cold start it should idle pretty high then drop down to normal temp and regular idle. Before it was gonna die it started to idle lower. Since you havent been driving it, the battery drained itself. So you have to jump start it. Let it sit and if it dies after you removed the cables its your alternator or battery.
+1
Old Dec 14, 2010 | 12:49 PM
tscompusa2's Avatar
hook a battery charger up to it and charge battery 100% then try again, if problem persists then im not sure.. maybe a huge grounding point is disconnected somewhere. check the ground on alternator and etc.
Old Dec 14, 2010 | 05:23 PM
thanks guys...im having the battery and alternator tested tomorrow
how easy is it to replace an ecu? i have a turboxs ecu but i dont have the data cable to tune it.
Old Dec 14, 2010 | 05:36 PM
sunrichmond's Avatar
whats your battery voltage while its running?alternator might be weak, you ever got your ecu mess with tuned? it look like you might have the maf sensor unplug or the coolant temp or iacv, check those harness for cutts or burns or any wires
crank sensor or cam sensor can do this also
Old Dec 14, 2010 | 05:38 PM
ecus don't usually go bad unless u accidentally log something wrong or water got into it,
Old Dec 14, 2010 | 05:41 PM
whats the easiest way to figure this out..i have lots of possibilities but no one has really said how to diagnose the problem other than the battery and alternator
Old Dec 14, 2010 | 05:45 PM
tscompusa2's Avatar
spark and fuel are effected by those sensors, so no.
Old Dec 14, 2010 | 05:47 PM
casper980's Avatar
I think its the battery. You said it, sat two years, and it was fine before it sat, then this happened. If you didn't have a trickle charger on the battery, then the battery is dead and will need to be replaced. If you have another car at your house, swap the batteries and test to see if she idles.
tscompusa2's Avatar
ussually caps go bad in a ecu first. it certainly wouldnt like water tho.
cant log something wrong and kill the ecu. you can kill the ecu if its not getting proper voltage tho and you attempt to write to its memory and it corrupts the flash.. can still be fixed tho. "debricked"
Old Dec 14, 2010 | 05:51 PM
tscompusa2's Avatar
do what i said and give the battery a full charge to 100% with a good charger. then start it up.
the car ran fine before right? its not a injector scaling/deadtime issue right?
also..... as i said before check for any loose or unhooked grounds.
with a full battery it will still run with no alternator for a good 15minutes depending how strong the battery is. on a mini battery maybe 3minutes
Old Dec 14, 2010 | 05:53 PM
i drove it for 240 miles before it finally gave out completely. if the alternator went out why all the sudden?
Old Dec 14, 2010 | 05:54 PM
yeap, your right , dint he mention something about having a different ecu??he might have to swap it with another and see what happens
