buschur cast hta35
Old Dec 17, 2010 | 12:59 PM
maxboostedevo's Avatar
buschur cast hta35
so this is my problem, I have a buschur cast hta35r .63 kit and want to go bigger, can I upgrade the back turbo housing to a .82 or .86 the way it is sitting now or do I have to do something else, I was also thinking of taking the cast manifold off and getting a tubuler manifold any help will be great thanks.
Old Dec 17, 2010 | 01:13 PM
Mellon Racing's Avatar
changing from a .63 to a .82 isn't going to do much for you unless you're running way over 30psi. I ran 10.41 @ 135 on a HTA3582 .63 with 93 octane at 30psi in a full weight evo (600awhp) I miss my old .63
Old Dec 17, 2010 | 01:40 PM
240Z TwinTurbo's Avatar
While Mellon did well using the .63 a/r, that does not mean the larger a/r wouldn't have benefited him as well. You should see top end gains going to a larger A/R. A reduction in the flow restriction within your exhaust will provide benefit regardless of boost. However, the gains may be more significant at higher hp levels/higher boost. The expected gains will really be dependent on whether the a/r is the limiting factor at this point.
Old Dec 17, 2010 | 02:07 PM
I have all the supporting mod my motor is back out of the car I am dropping in rods and pistons plus main stud and bearings, I also have the dual pumper and the rest of the things so I am just wonder I can just buy a .86 or .82 back housing for the turbo plus manifold and do the upgrade. I want 700 plus whp
Old Dec 17, 2010 | 02:16 PM
going from a HTA3582 .63 to a HTA3586 .82 gave me no more power on 93 octane at 30psi and only added lag. I always speak from experience, not my ***
Old Dec 17, 2010 | 04:07 PM
I have been turbocharging cars for more than 13 years and used to sell Garrett Turbochargers so I do speak from experience. You're a typical pompous dealer on this forum who tries to belittle others who provide a different point of view. I simply provided my opinion on the matter and didn't bash you, but you somehow feel obligated to bash me.
I am always open to a good debate so let's go. You swapped to a larger compressor wheel and turbine a/r so perhaps you didn't see gains because you had flow restrictions on the intake side of the motor. Clearly you don't understand your own example and justification.
Old Dec 17, 2010 | 04:19 PM
I also wanna run e85 and maybe upgrade my 1450s to 1600 injectors
Old Dec 17, 2010 | 08:49 PM
MODERATOR, WHY IS THIS VENDOR BASHING ME FOR PROVIDING MY INPUT?
You're providing opinions, I'm providing proof
Old Dec 17, 2010 | 08:51 PM
R/TErnie's Avatar
I've tested enough turbine housings back to back to know that the larger turbine housing will produce more power.
And I did it on a REAL dyno.
Old Dec 17, 2010 | 08:52 PM
I ran 1650cc at 700awhp and the IDC was about 80% on e85 with twin walbros punched down reliefs, fuel rail upgraded. The newer high impedance FIC 1680's would be perfect for your setup but if you want more room for growth I suggest the fic 2150's. I'm seeing 50% IDC at 600awhp with them on 93 and haven't tried e85 yet on higher boost. I think they'll be enough 800+awhp, likely the last injectors you'll ever need to purchase.
p.s. now that you've mentioned your goal, the .82 and tubular header would be ideal for your setup
Old Dec 17, 2010 | 10:04 PM
You are correct and that was my point as well. You only need to look up flow numbers on Garrett's website to understand a larger A/R flows more when talking comparable housings. I was very careful in my initial post to say the following...The expected gains will really be dependent on whether the a/r is the limiting factor at this point. My point was directly applicable to Mellon's issue that he lacks flow on the intake side of the motor.
Old Dec 18, 2010 | 05:45 AM
you guys keep talking about theory and I'll keep producing the results. Show me somebody that got significant gains at 30psi on 93 octane with a 35R by going from a .63 to a .82 on a well prepped evo. I said there will be gains with better fuel and higher boost.
Old Dec 18, 2010 | 05:59 AM
VRSF Tiago's Avatar
Ease up brother, he's not bashing you, he's simply stating that swapping housings had no benefit in his previous experience.
@ 30 psi on pump there simply won't be enough gains to justify the swap & the increased lag. 40 psi on e85 is a totally different story though. I think both of you are correct in a sense, just debating based on mis communicated facts.
Old Dec 18, 2010 | 06:23 AM
Smike's Avatar
Discussion is civil. Lets keep it near that.
Old Dec 19, 2010 | 04:30 PM
thanks for the inputs but you guys haven't answered my questions yet but on with those great comments to each other.
I WANT TO KNOW IF I CAN JUST CALL FP AND ORDER A BACK HOUSING AND THATS IT THANKS.
and thanks mellon for those advice to get 700whp
