wtf is goin on !?
Old Dec 18, 2010 | 05:09 PM
dinok's Avatar
wtf is goin on !?
so driving my car and when clutch engaged or standing tstill the car is hittin 2200 rpms and afr is reading --- :X !!!!
turned the car off then on again and everything was fine why the hell was my car forced at 2200rpm with clutch engaged and driving under2200 rpms it wud drive itself ina way
then turn the car on and off its fine ??
Old Dec 20, 2010 | 09:20 AM
dinok's Avatar
wud anybody know why my car wud be hanging at 2,000 rpms ?! then when i turn it off and on it goes away ?
Old Dec 20, 2010 | 09:28 AM
gsrboi80's Avatar
Clutch in you mean?? That is disengaging the clutch.
Was the car warm?
Old Dec 20, 2010 | 09:29 AM
escodotcarter's Avatar
maybe throttle cable got stuck? .......when it was hanging did you try to give it gas?
Old Dec 20, 2010 | 09:30 AM
4RETECH's Avatar
ISC motor maybe. Or even your coolant temp sensor to the ECU is not reading correctly and is telling the ECU your engine is still in warm up. Use Evocan and check it out.
Good Luck
Old Dec 20, 2010 | 10:21 AM
dinok's Avatar
with clutch engaged and disengaged it happens
when i give it gas it goes loll
just dont wannt fudge nething up
Old Dec 20, 2010 | 01:44 PM
cij911's Avatar
Wow...you should probably not drive the car then ...
Also, the word is "nothing", not "nething"....
Old Dec 20, 2010 | 02:39 PM
dinok's Avatar
but when i turned the car off and then on again it was fine ??
Old Dec 20, 2010 | 02:56 PM
Teal2nnr's Avatar
^^^ Hook it up to a laptop, use Evoscan.....you will find your awnser
Old Dec 20, 2010 | 03:16 PM
dinok's Avatar
where can i get evo scan ?
Old Dec 20, 2010 | 03:44 PM
Azlan of Narnia's Avatar
I found this to be hilarious. Good luck OP.
Old Dec 21, 2010 | 09:27 AM
dinok's Avatar
when the car is STANDING STILL wether clutch is engaged OR not the rpms hand at 2200
when i release the clutch ina gear it drives itself in a sense up to 2200rpm then when i control it on the gas pedal it drives normally
now when i turned the car OFF then back ON again the car was fine
the car was warmed up
just had my waterpump changed with my 60k kit
anyone have ne advice ??
Old Dec 21, 2010 | 09:29 AM
dinok's Avatar
yea everythings funny when it isnt happening to you ... if u dont got nethin to say positvely to the subject then shut it homie
Old Dec 21, 2010 | 10:18 AM
dinok's Avatar
Good Luck
what does ISC motor maybe mean ??
Old Dec 22, 2010 | 04:49 AM
4RETECH's Avatar
Idle speed control motor. Attached to throttle body with three screws. If it's bad Mitsu charges over $300. Get it from Amazon instead at $160
