The Misfire That Wouldnt Go Away! Help!
Old Jan 1, 2011 | 01:59 PM
JakeTheVIII's Avatar
Hey I figured out how to get the logs and open them and everything. But yea, it didn't log some of the stuff that I wanted/thought it would. We'll have to log it again or something...I'm still a noob with evoscan. I think that's normal for the timing though, the logs look pretty close to the timing maps and it's a stock map so that should all be fine. I don't think it's timing belt related either because it will rev out fine if its not in 15ish+ psi, right? Lets get some good logs with more data and then we can post them up.
Old Jan 3, 2011 | 09:44 AM
JYD's Avatar
JYD
sounds good. im still thinking that the giant timing retard when its misfiring is not normal....just dunno whats causing it.
Old Jan 3, 2011 | 10:41 AM
RJSP's Avatar
Just a few couple weeks ago I was having a similar issue with my car, in the logs the missfire would happen with a reducction in timing of like 10 - 12 degrees and there was no knock... It turned out to be the cam angle sensor. I also discovered though that the missfire would occur even when reving in neutral, so it wasn´t boost related at all.
Good luck,
Ricardo
Old Jan 3, 2011 | 05:11 PM
JYD's Avatar
JYD
mine seems to be directly boost related, feels like its blowing the spark out. but the coils check out good, and the plugs are factory, brand new and gapped at .020. gonna try throwing some parts at it tomorrow, and see what happens.
johnashton11
11
Sep 13, 2019 01:23 PM
NYREDEVO
Nov 13, 2008 06:04 PM
ExViTermini
Nov 25, 2007 08:19 AM
berkel
51
Apr 7, 2006 08:54 AM
gregivq
Lancer Troubleshooting
22
May 10, 2005 09:34 AM
