280 degree cam, is it ok for a stock bottom end.
I have searched and read a couple different threads and haven't really come to a solid conclusion.
I am about to have some Kelford 280 cams installed along with BC springs. I have read that the lift and duration on the 280 is too much for a stock bottom end. Causing valve to piston contact resulting in bent valves.
How much lift can you have with a stock block? Do you have to resort to a different piston, one with larger valve reliefs?
Thanks in advance.
Thanks in advance.
General rule of thumb, on a stock bottom end, I wouldn't go any further then 272's on a stock bottom end. Build the block and then you can go 280's, as for max lift, check out the moding for dummies thread.
OMG-- what a bunch of BS-- yes you can use the 280 cams, thats a lot of cam for a stock engine and will push the power band out of the range of a stock turbo so not a good combination. Yes, the bottom end will hold together for now. Cam duration and lift have absolutly no effect on the bottom end or the engine staying together-- how heavy your foot is and the rpms you are turning have everything to do with that. Get stupid and anything will come apart--even a " built" bottom end.
You all have misunderstood what I am asking, rather I probably should have worded it differently but I figured I did it easy enough.
What I was asking was can you run a 280 degree cam, the lift is 11.5mm (per Kelfords website).
What I am concerned about is will the valve hit the piston with these cams? I know the stock piston has a small valve relief in them but is it deep enough for the additional lift? The clearance is what I am concerned about.
As far as my build check my garage.
Description: My toy, track and autocross.
Engine/Drivetrain Modifications: Bolt Ons, APEXi WSII catback, AEM EMS, Full Race Prostock kit,
Suspension Modifications: TEIN Type N1 Dampers, Carbing bars.
Wheels/Tires Modifications: Yokohama Advan RS-D wrapped in Neova rubber: Street
SSR Type C wrapped in Toyo R888 rubber: Track
Interior/Exterior Modifications: Takata and BRIDE Gradiation.
Future Modifications: Not much more, just track time, more extensive tuning to dial in all the components.
You are using the AEM EMS, so tuning the Cams will not be a problem.
But they are big Cams, Man.
May be you should try their 272's with your set-up. They are awesome and not as agressive.
You can always go bigger later as you out grow them.
Going to give Kelford a call to find out.
Even if the Cams fit and there is no issues with clearances and what not, there are other factors to should take into account.
I was giving you one of those other factors.
Go with the 11.5 lift Cams. You will see.
go with them
