Are adjustable cam gears needed?
Old Jan 6, 2011 | 04:43 PM
Cesare87's Avatar
Could someone tell me if adjustable cam gears are needed for hks 272's? would gains still be seen when using stock cam gears?
Thanks.
Old Jan 6, 2011 | 04:51 PM
4RETECH's Avatar
Not needed, with gears you can move your powerband though.
Old Jan 6, 2011 | 04:52 PM
raiceboi697's Avatar
most cams are designed to be set straight up and there is no need for a adjustable cam gear out set of aesthetics unless you need to move your powerband to the left or right for how your car is set up
Old Jan 6, 2011 | 04:59 PM
Cesare87's Avatar
Thanks for the replys, gains will still be seen when using the stock cam gears?
Old Jan 6, 2011 | 05:12 PM
BAD-LSX-7's Avatar
yes u will still se great gains with stock gears
Old Jan 6, 2011 | 05:16 PM
Teal2nnr's Avatar
Gears dont change the "gains" in specific, cam profile does
Old Jan 7, 2011 | 09:41 PM
awdordie's Avatar
Gears will affect it slighty as most are lighter than stock but nothing major and hks guarantees like 60 horses after installing the 272s and a tune.
Old Oct 5, 2012 | 12:01 PM
SloGST's Avatar
I installed HKS 272/272's on my Evo, which is running the stock IX turbo, and I saw a significant loss in low range power, but a nice extra 25hp in the higher rpm range. My advice is to get adjustable cam gears, you will need them to shift your powerband to a lower range with the 272's, they will slow down your spool-up process a small amount as well. Regardless, cams need to be dialed in and degreed correctly, and sometimes shifted one way or another to better suit your current setup/tune.
Old Oct 5, 2012 | 02:10 PM
todd6027's Avatar
waste of time fitting em without adj pullies
MisUnderStood
Jan 27, 2017 10:11 AM
dillons13
Oct 10, 2016 10:52 AM
badev0
Feb 17, 2016 01:28 PM
Skidonner90
Jun 24, 2015 02:29 PM
turbo dragon
Nov 22, 2010 06:40 PM
