SUPERTECH VALVES +2mm?
Old Jan 13, 2011 | 02:11 AM
mnf's Avatar
mnf
Hi...
Do i need custom pistons for SUPERTECH VALVES +2mm ?
Im using GSC S3 cams
STD vs +2mm Horse power difference ?
Is it worth?
Regards,
Old Jan 13, 2011 | 02:24 AM
Ted B's Avatar
Originally Posted by mnf
Hi...
Zero
The weak link in the head is the port, not the valve. Larger valves without extensive head work won't help you, and may result in worse flow than factory.
Old Jan 13, 2011 | 03:19 AM
mnf's Avatar
mnf
Thanx for info
