Difference in Evo 4 to 8 drivetrain?
Old Jan 16, 2011 | 06:58 PM
4RETECH's Avatar
I was just wondering if anyone has any experience with this??
I'm thinking the engine is the same(minus sensors, hoses)
Someone I know is trying to buy a shell and put this drivetrain in it.
The trans and transfercase?? Same gearing??Of course Non ACD.
Thanks for any input.
Old Jan 16, 2011 | 08:00 PM
TheMadScientist's Avatar
The transfer cases and driveshafts are different, the trannys are interchangeable. I'm running an Evo 8/9 5 speed tranny in my EVO 6.5
Old Jan 16, 2011 | 10:48 PM
KX250Fmotoracer's Avatar
You're buying an Evo 4 engin for an Evo 8, or an Evo 8 for an Evo 4?
Old Jan 17, 2011 | 05:42 AM
4RETECH's Avatar
Sorry, yeah he's trying to get a Evo 8 rolling shell and put a Evo 4 drivetrain in it.
Old Jan 17, 2011 | 07:03 AM
He's gonna need the evo 8 transfer case and driveshaft. Also all the evo 8 rear sub assembly stuff. Also he may need the two side motor/tranny mounts, I'm pretty sure the other mounts are the same. They actually share quite a few components. It all depends on how much of each he has.
Old Jan 17, 2011 | 07:22 AM
-the harness is pretty different, and will be RHD instead of LHD.
-injectors are smaller
-you will need to do some wiring to make an Evo 8 ECU work (to pass emissions, evo 4 is OBD I)
-the turbo is smaller
-I'm pretty sure the transfercase is smaller, im not sure if it will bolt into place or not. There is no ACD though.
-Driveshaft is a different length IIRC
The whole rear suspension is different from 4 to 5 (10mm narrower, steel control arms, etc). 5-8 will work though
-axles may be 10mm too narrow (have to check though)
-02 Sensor has no heater element
Thats all I can think of off the top of my head
Old Jan 17, 2011 | 07:28 AM
german_evoVII's Avatar
If you use an Evo 4 Transfer case, you will need the evo 4 Rear Diff.
If using an Evo 7 to 9 Transfer, you need an Evo 7 to 9 rear end.
Reason:
The Evo 4 to 6 had an different Transfer ratio ( Hypoid gear set ) than the Evo 7 to 9 Transfers.
Old Jan 17, 2011 | 07:34 AM
4RETECH's Avatar
Thanks guys, I'll let him know.
It's a shell (2003 Evo 8) with wiring and ECU still there. Rear end still there too.
He just wanted to make sure at least some things would work.
He said he did something similar with a Subaru, but things didn't match up at all,LOL
Old Jan 17, 2011 | 07:49 AM
vik's Avatar
vik
Please don´t forget the Evo4 engine is not such good as 5 and onwards.
It has issues with crancwalk.
Injectors are smaller but there is no huge difference.
Subframes are smaller as written above
Front diff is open (can cause inner wheel spin in turn) - Evo 5 onwards changed to LSD type
I´m missing point put Evo 4 internals on Evo 8 sorry
Old Jan 17, 2011 | 07:53 AM
My E4 transfer case is LSD, and yeah the thrust bearing on the E4 is the same design as a 7 bolt DMS, no biggie though.
kambodianboi
May 11, 2010 07:59 AM
Pivotto
Aug 23, 2009 03:08 PM
KPerez
Mar 23, 2008 05:31 PM
RalliArtEvoVIII
Jan 23, 2007 06:53 AM
AznFlip
Lancer Tranny/Drivetrain Tech
38
Nov 8, 2004 10:04 PM
