Idle drops and stall during cold start and when the fan turns on
I've searched all the related problems but couldn't seem to find the same problem that I have.
Currently have Evo IX - MR 2006
After the Speed density installed and the tune, every time when I Cold start, it will first go up to 1.5-2k rpm and then all the sudden drops to 0 and stalls when the fan turns on. I've double check with the tune, shouldn't be the problem. I tried turning the TB idle screw ccw all the way and it still stalls in cold start when the fan turns on..The idle also bounces up and down when I go into neutral while rolling down the street..but when I do a complete stop..The idle will stop bouncing.
If anyone has any idea whats going on...please let me know
I've cleaned it and tried almost everything..The idle is a bit smoother...but it still stalls during cold start...maybe its the SD? because the tune I contacted my tuner and he gave me another map for it..so I don't think its the tune. Also did a vaccum leak check...and nothing
Don't mess with the IAC.. 05VIII is on a IAC rampage lol, But I want to welcome you to the SD Family we all deal with this in cold weather just when you first start it as it starts to drop tap the gas a little and get it to shoot to about 2k and it will idle there for a bit and I know my im lean at idle but with SD on the Euro Map it does not have a setting to add fuel at idle only. Also depending on your adjustment of your idle it will be rough and sound like its going to die but 99% of the time mine only died once. Its nothing to worry about its just we dont have the settings and the MAF to make all the corrections now. It wont happen in summer at least when it was 50+ I did not have this issue at all.
My Evo 9 had this same issue - I tried all kinds of settings in the map nothing helped - its a combo of things Cams, intake, Maf, Fueling etc...
When I switched to the Haltech ECU it pretty much disapeared.
I'm going to bump this up because the problem is still occuring..I've tried to search on this forum but nothing yet, I want to adjust my ecu flash map but I am not that familiar with it. I heard the Mivec Intake advance mapping can be adjusted to fix the AC turned on Issue, but how about for just normal cold start I don't understand where I can change the mapping to fix the 5 min warm up and prevent the car from dying.
phishy
Dec 20, 2011 12:46 PM
