Turbo blanket for stock turbo?
Old Jan 20, 2011 | 10:58 AM
PaperClip's Avatar
yeah I was skeptical about the gain. I am more worried about the heat like you said. Even though I am going to be running a stock 9 turbo I am going to be putting it through some abuse this summer. Auto X and some HPDs at summit point.
Old Jan 20, 2011 | 11:09 AM
n2oiroc's Avatar
The big thick blankets work better than anything else for heat management. Wrap is right behind and i feel ceramic coatings are the least effective, but the best looking. Only downsides to wrap and blankets is they can smell like you are baking a loaf of bread under the hood until you burn the chemicals off of them.
Old Jan 20, 2011 | 11:14 AM
EvoDan2004's Avatar
i wish they had one for the T4 1.06 housings. i would buy one
Old Jan 20, 2011 | 11:17 AM
n2oiroc's Avatar
They are somewhat universal. I would think a std t3 blanket would fit just fine. If it helps i have a used one laying around if you need measurements or pics.
Old Jan 20, 2011 | 11:24 AM
EvoDan2004's Avatar
i believe dave said it might not fit. but was not 100% sure.
its up to you if you want to measure it. that would be nice of you if you got the time
Old Jan 20, 2011 | 11:33 AM
06MREvo's Avatar
ummm...I may have to pick one of these up...just for the drop in under hood temps...
Old Jan 20, 2011 | 11:37 AM
n2oiroc's Avatar
Old Jan 20, 2011 | 11:40 AM
EvoDan2004's Avatar
thanks. let me see if i can take some measurements of the housing
Old Jan 20, 2011 | 12:15 PM
blknblubkrdude's Avatar
Anyone know if there is any interference with these and the oem heatshields? Im very interested! Thanks
Old Jan 20, 2011 | 04:08 PM
David Buschur's Avatar
Evodan, we have them for the T4 too. They will not fit with the oem heat shield on the stock turbo.
Old Jan 20, 2011 | 05:48 PM
Evoardo IX's Avatar
so, If we install the blanket we have to run without the heatshield? or is there a heatshield that fits with the blanket in place?
Old Jan 20, 2011 | 07:32 PM
BiFfMaN's Avatar
The blanket will do a better job then the Heatshield.
Be cool if someone could make a Blanket to fit on the stock Exhaust manifold, im sure it would sell.
Old Jan 20, 2011 | 07:40 PM
n2oiroc's Avatar
The blanket and heatshield do 2 different jobs. I would trim the shield to fit around the blanket.
Old Jan 21, 2011 | 02:36 PM
You are speaking of the DEI blanket, correct? - https://secure.buschurracing.com/cat...98fe5beba3f99a
Old Jan 21, 2011 | 07:07 PM
Yes, just specify which one you want.
