Turbo blanket for stock turbo?
Old Jan 21, 2011 | 10:25 PM
  #31
sparky's Avatar
Editted
Old Jan 21, 2011 | 10:49 PM
  #32
EvoDan2004's Avatar
Originally Posted by davidbuschur
Evodan, we have them for the T4 too. They will not fit with the oem heat shield on the stock turbo.
o. i did not know that. i will have to call and pick one up.
Old Jan 21, 2011 | 11:38 PM
  #33
sparky's Avatar
Editted
Old Jan 22, 2011 | 01:47 PM
  #34
mikakatk2's Avatar
interesting
Old Nov 11, 2013 | 06:18 AM
  #35
JaYr_EvO9's Avatar
Originally Posted by David Buschur
1whp/1ft lb is pretty damn hard to say is a gain. Anyway..........the theory is that the spool up is better by retaining the heat.
I'll be dead honest on this, the #1 reason to run the blanket is pure safety. That turbine housing is FARKING HOT!!! IF oil hits it you have an instant fire, INSTANT. Oil line on the turbo fails, you knock a rod through the block etc. The car is going to catch on fire if oil hits the hot turbine housing, I've seen it happen more times than I care to remember.
It does, absolutely, keep under hood temps lower too. Dyno'ing an actual gain is tough.
Old Nov 14, 2013 | 11:30 AM
  #36
ILuvJDM's Avatar
So using a DEI T3 turbo blanket will work with stock frame turbos, correct?
Old Nov 19, 2013 | 11:21 AM
  #37
Redliner23's Avatar
I'm just finding all my answers today exploring the forum lol. Gotta get that turbo blanket for my next turbo. contemplating rebuilding mine or just getting another one. Either way Ima getta blanket
Old Mar 23, 2018 | 06:13 AM
  #38
andrei_blancia's Avatar
Looks like i came late to the party so i'm reviving this thread back from the dead. Anybody here has placed a turbo blanket on a stock turbo/stock frame turbo with the heat shield on, or did you have to trim it? I'm planning to put this in an Evolution 6 with the OEM turbo and heat shield. Hoping to reduce temperatures under the bonnet as it reaches around 45-47 degrees C (as per my climate control unit, im sure its waay hotter than that).
Thanks!
Evo6Point5
27
Dec 22, 2024 01:37 PM
foxbat
Dec 22, 2024 01:35 PM
cmoore
Feb 7, 2016 04:27 PM
churchja
Jun 6, 2010 05:33 PM
RU EVO
17
Mar 11, 2010 01:37 PM
