View Poll Results: Any problem w/ Autometer boost gauge reading zero at idle?
Yes...due to defective gauge
14.00%
Yes...but due to install problems
2.00%
No problem at all
42
84.00%
Voters: 50. You may not vote on this poll
Autometer boost gauge users please take poll
Old Dec 8, 2003 | 11:51 PM
SzuChenEvo's Avatar
Did your autometer boost gauge have trouble staying at zero when the engine is off? I've seen a few pics and some of them seem to read a tic below zero. I'm planning to purchase an autometer boost gauge very soon so want to make sure. Please post the model type if you have a problem...thanks!
also...anyone know where's the cheapest place to get the Z-series? I just want an autometer that matches the interior lighting, doesn't have that silver border some autometer gauges have, and reads up to 30 psi...thanks!
Old Dec 9, 2003 | 12:16 AM
3K's Avatar
3K
What do you mean "read 0 at idle"? If your gauge reads "0" at idle then it's broken. It should read between 16-18 in/hg at idle.
I think what someone was mentioning about the gauge being off at "0" is that the pointer wasn't exactly centered in the square when the engine was off.
I had three autometer boost gauges so far, two ultra light gauges one was perfectly centered and the ohter was slightly off of "0" but they both read exactly the same when under boost.
I now have the cobalt boost gauge, which is an electronic gauge. I like it. Although it's not as cool as some of the JP products, I think it looks pretty good. It's also pretty consistant.
Old Dec 9, 2003 | 12:28 AM
SzuChenEvo's Avatar
thanks for the post...just corrected my question
Old Dec 9, 2003 | 12:31 AM
superz's Avatar
the Autometer guages are one of the best bargains in my mind. Why go out and spend 2 and 3 times the money on another guage when the single most popular guage used in proffesional racing in the US is Autometer. I have used them in the past and I've never had any problems.
Old Dec 9, 2003 | 05:29 AM
MrBonus's Avatar
Probably the same reason that people will buy 1200 dollar JDM titanium cat-backs when Buschur's is a few ounces different and flows better for 450.
Old Dec 9, 2003 | 06:38 AM
fastmarsh's Avatar
I have the 2 5/8" boost gauge and I am very happy with it. Just make sure that you seal all of the connections that you make.
A little (Microscopic leak) will make it read wrong. Also use the teflon tape on the gauge.
Old Dec 9, 2003 | 07:59 AM
MrBonus's Avatar
Where is the best place to pick up an Autometer boost gauge?
I'm guilty of not monitoring my boost levels.
Old Dec 9, 2003 | 10:02 AM
SzuChenEvo's Avatar
i just bought mine at motorhead.com for about 70 bucks w/ pod and shipping...the best price i've found.
Old Dec 9, 2003 | 10:46 AM
kdogg's Avatar
Cheapest i've found...
www.summitracing.com
Old Dec 9, 2003 | 11:23 AM
MrBonus's Avatar
Thanks, guys.
Which gauge pod are you referring to?
Old Dec 9, 2003 | 12:17 PM
Secret Chimp's Avatar
how easy is it to install? ie....what connections do you have to make?
Old Dec 9, 2003 | 01:45 PM
djtmotorsports's Avatar
I always use Lane Automotive in Michigan. 800-772-2678 my salesman is at extension 272, his name is Charlie. Usually competitive pricing, always in stock. Make sure to tell him that Darin at DJT sent you.
Old Dec 9, 2003 | 02:18 PM
rebelzx's Avatar
I dropped mine before install. Now it reads a little bit under 1 when off. It makes no difference, because the gauge still reads correctly.
Old Dec 9, 2003 | 03:44 PM
eevoo's Avatar
Mine works great. The red "condom" that fits over the bulb is a perfect match for the dash lights in my opinion. Only two connections you have to make: Tee it into the BOV or FPR line, and connect the power line to a 12V source for power (and ground of course). Burschur (and I'm sure a few other places) sell a little cup to put it in that mounts on the column. Just saw the mounting bolts a little shorter and it pops right in.
Old Dec 9, 2003 | 03:52 PM
inrpce's Avatar
If it is a mechanical gauge, and it does NOT read 0 when the car if off, you need a new gauge. For example: If your gauge reads lets say..... 1psi when the car is off, and you running exactly 5psi of boost the gauge will read 6psi. I had this same problem with my first autometer gauge. I dropped it and it was reading about 1.5psi when the car was off.
6.895 kPa is exactly 1psi. When my car was off, my AFC was reading .3 or .4 kPa. .4 kPa != 1.5 psi. You can clearly see that the gauge is inaccurate.
Need i say more? i don't think so. Get a electronic gauge, and don't mess with a crappy mechanical gauge. The innacuracy is just too much for me to deal with, but maybe i'm a profectionist.
