Evo 9 Turbo swap, Tuning??
Old Jan 22, 2011 | 08:32 AM
erald01's Avatar
yeah right now its on stock boost, i am sure ill be fine. I talked on the phone with a few shops and they told me ill be fine, even though the evo9 flows more air the stock selenoid (oem boost) is set for an evo 8 so the boost will still be at 19.5 psi tapering to 16 psi by 6500 rpm. Evo 9 turbo runs at 20 psi tapering to 17 psi by 6500 rpm.
Old Jan 22, 2011 | 12:55 PM
mifesto's Avatar
Originally Posted by erald01
I thought it would not be a problem due to the fact that the evo 8 vs evo 9 turbo is not that difference on oem set up. The evo 9 turbo only boosts 2 psi more..
its not about what psi it runs, its about flow. you have an '03 so an '05 hotside only is a minor step up. a evo9 turbo has the 10.5 outside(05's evo8 had them) AND also the bigger compressor side. so combine those two, its not "minor". either way just dont beat on it yet.
4dooradam
Jun 21, 2016 06:29 AM
rschaffer
16
Jun 12, 2012 10:52 AM
ctevo
Evo X Dyno Results
11
May 31, 2012 06:02 AM
ralliartsmart
Apr 2, 2011 08:34 PM
talon2evo
Mar 2, 2006 08:45 PM
