3" GM MAF Question
Old Jan 24, 2011 | 06:06 PM
GrnEVO's Avatar
Question 3" GM MAF Question
So when I bought my car, it came with a 3" GM MAF and MAF translator. Ok, I can work with that and learn about it, no big deal. My real question here is about the BOV. I currently have a 9 bov but I was wondering if it would hurt to run a VTA and just get an SD type intake. Of should I just leave it the hell alone, lol? Here's the setup currently.
Old Jan 24, 2011 | 07:22 PM
cij911's Avatar
Run SD...(get rid of the MAF / MAF translator)....or just get the stock MAF ...
Change the filter while you are at it too....
Old Jan 25, 2011 | 07:57 AM
turbolarry's Avatar
It should be OK to go VTA since the sensor is after the BOV. The ecu will see less air and should compensate with less fuel. I've never used a gm maf, only read about them, but if the translator is set up right you shouldn't have a problem. If it starts acting up, then through the IX valve back in there.
Old Jan 25, 2011 | 12:31 PM
dsmfan95's Avatar
Yes you can VTA before the sensor.
Old Jan 25, 2011 | 02:16 PM
GrnEVO's Avatar
Why do you say to get rid of the MAF translator? It's set up perfect right now and I have absolutely no issues. I really just want to run either a VTA or run the IX BOV from the upper intake pipe because I don't like my BOV and lines being so close to the manifold. Can I recirc the bov from the uicp to the intake or does it HAVE to be done the other way around?
Old Jan 25, 2011 | 08:38 PM
maperformance's Avatar
Keep the MAF and the translator we have made over 800whp on that setup before. This was before SD. If the care runs fine and makes the power you want, then there is nothing to do but change out that BOV and intake. Good lord get rid of that filter
Don't fix it, if its not broken. But that filter comes factory "broken" haha.
Go to Turbosmart Raceport 50mm VTA blow off valve because its pure bad *** (Pm me for a price) and snag up a ETS SD intake, which I can also hook you up with.
Old Jan 25, 2011 | 08:45 PM
evoredy's Avatar
I've always noticed that my car idles beautifully with the MAFT and a GM MAF compared to a mitu unit in all of my testing. No hacks, no SD, no this or that/just minor scaling adjustments.
The stock EVO MAF just sucks at handling idle fueling with larger turbo's, MAF pipes, IC pipes, etc. WOT and P/T cruise is spot on though time after time.
+1. If it works great, why swap it out? GM MAF's are easy to come by and easy to visually inspect also.
Old Jan 25, 2011 | 08:55 PM
Agreed.
Old Jan 25, 2011 | 10:18 PM
RockmanX's Avatar
have to agree if its working well just leave it alone. besides MAP Preformace should know that car well
Old Jan 25, 2011 | 10:32 PM
nikg's Avatar
Keep the gm mas and maft thats a good setup. I would leave the stock bov recirc tho until you get an aftermarket one. Oh and to answer your question ya you can put the Bov on the uicp and run the recirc tube to the intake. You may need to reedo the recirc pipe tho.
Old Jan 26, 2011 | 03:31 AM
GrnEVO's Avatar
Thanks for all the replies, I think I'm gonna get the SD type intake and a Turbosmart bov. Hey Adam, what's up with the price on those two, lol
Old Jan 26, 2011 | 07:36 AM
Is that Kasey's old car? Thought he traded it for a Silver MR?
Old Jan 26, 2011 | 09:00 AM
GrnEVO's Avatar
haha, yeah it's Kasey's. That's why Rockman said you should know it pretty well, lol.
Old Jan 26, 2011 | 09:07 AM
ETS Michael's Avatar
Looks to be
Old Jan 26, 2011 | 01:52 PM
GrnEVO's Avatar
car's freakin awesome, just got to change out a few things to my own preference and get a new tune for her.
