screeching noise with clutch pushed in - quartermaster twin disc
Old Jan 29, 2011 | 09:34 PM
Lucas English's Avatar
We will find out planing to head up Monday to get the car.
Doubt pressure plate since they normally will not give the full neutral feel. I am either guessing the hydraulics are pumped up, stripped splines on the clutch disc or who knows.
May have been right when it left the shop a few mons ago but as the clutch wares it may need to be re adj.
If its the fingers hitting the disc form over throwing you can tell because if you only push the clutch down enough to just get in gear which might only be 1/2way or 1/4 and the noise is not there.
Old Jan 29, 2011 | 09:43 PM
anthonyrb98's Avatar
awesome. thanks aaron. i will call u guys tomorrow.
Old Feb 12, 2014 | 09:03 PM
polishboy's Avatar
Hey,
I came across the same problem today. Can anyone of you tell me what exactly caused this and how I can fix it? Thank you
Old Sep 5, 2019 | 05:08 PM
littlered's Avatar
hi Anthony, just replaced my quartermaster clutch and its doing the exact same thing yours was doing. did you ever figure out what caused the squealing noise? trying to sell my car asap and need to figure this out. really appreciate a reply. thanks
Old Sep 5, 2019 | 05:14 PM
littlered's Avatar
did you ever figure out the issue with the clutch squealing?
Dann
May 15, 2025 06:16 PM
Chris725
Nov 24, 2015 06:40 AM
SilentEvo8
Aug 22, 2014 01:10 PM
Mr2fine
Nov 29, 2012 09:22 PM
jrank3792
Feb 4, 2012 11:55 AM
