5th gear vibration
Old Feb 1, 2011 | 07:54 AM
tjadams3721's Avatar
5th gear vibration
I never really use 5th gear much unless I'm really getting on it but the other day I took my car out for a nice drive and I noticed a bad vibration when I'm in 5th but only while on the gas. Going down hil coasting in 5th there are no problems but as soon as i touch the gas i get this horrible vibration that feels like an unbalanced driveshaft but the problem is not speed related, it seems more torque related. I drained my trans fluid and noticed some small metalic pieces. Could my vibration be caused by a bad 5th gear? Like bad contact or not meshing well on the main? I really don't want to pull the trans out if i'm just missing something simple any help would be great
Old Feb 1, 2011 | 08:40 AM
mifesto's Avatar
are you getting a p0300 code? there is a chance that code is disabled in your ecuflash too.
worst case is your input shaft is worn, some 03's have this issue (including mine). rebuild is necessary then.
Old Feb 1, 2011 | 08:54 AM
I don't have any lights on but i'll see if I can borrow a buddy's scan tool to see if any codes were set oor if any are pending. Did you have a gear specific vibration problem too?
Seamus7
18
Jul 30, 2016 03:12 PM
pb91
Jun 8, 2011 02:44 PM
enpe
Jan 23, 2011 12:39 PM
J.P. Mo
Lancer Troubleshooting
Aug 13, 2010 02:13 PM
m0nkie
12
May 2, 2010 06:03 PM
