oil pressures after oil cooler delete
Old Feb 1, 2011 | 11:14 AM
Drill_Sergeant's Avatar
Veteran: Army
for those who have deleted the oil cooler and just blocked off the lines, what are you seeing typically for idle pressures and cruising pressures?
and how long of a M18x1.5 bolt/plug are you using?
Old Feb 1, 2011 | 12:27 PM
RSMike's Avatar
technically you shouldn't see any change in oil pressure.
You will only see a change if the oil relief valve cannot flow enough oil, causing pressure to increase.
in saying that the oil cooler doesn't "lose" oil pressure like large clearance bearings etc, it's all contained.
Old Feb 1, 2011 | 12:35 PM
Ghost1t's Avatar
why did you remove the oil cooler? Just wondering if it has benefits
Old Feb 1, 2011 | 12:56 PM
gsrboi80's Avatar
Likely blown engine. Cannot reuse (without ultra sonic cleaning) which I wouldn't go for and likely just end up with an aftermarket piece.
Yea I'm sure it benefits or Mitsu engineers would not have put one there. However many a built EVO from many well known camps on here don't run them.
I have not seen any testing in temps with vs. without though I couldn't see not running one on a road race car.
Old Feb 1, 2011 | 01:30 PM
RSMike's Avatar
i ran without an oil cooler for my initial engine break in.
oil temp very very quickly rose to 120deg C (248F) so the load had to be reduced a lot.
Old Feb 2, 2011 | 12:20 PM
Ghost1t's Avatar
Oh Ok, I still have mine , Oil temp don't rise that much never seen it above 90 only when on the dyno
94AWDcoupe
182
Feb 17, 2025 10:42 PM
STM Tuned
Feb 9, 2016 06:16 AM
Evo3573
35
Sep 18, 2011 10:17 AM
gudmundur
24
Nov 12, 2008 01:56 PM
teddy
13
Nov 20, 2007 03:17 PM
