one WG on divided manifold ?
Old Mar 6, 2011 | 09:40 PM
  #46
Drifto's Avatar
Originally Posted by bzyq2001
if i remember corectly, valve on the WG isn't flat, right? that divider must be in shape of the valve?
You are correct. The divider must be concave to match the convex valve
Originally Posted by Ted B
The divider was carefully fabricated to fit.
Extensive use of a common childs toy is used to check correct shape and clearance.
Just a few mm.
It's a good bit closer than that, but I'm not telling how much
This is what the bottom of the WG valve should look like if it's done correctly. You can see there is almost no cross contamination between paired cylinders. This valve was removed after several miles of casual driving to show this effect. If it had been removed after WOT you would not see this line due to the valve being off the seat.
Old Jun 21, 2014 | 06:14 AM
  #47
tutuur's Avatar
Please tell me the distance, looks like you got it perfect!
STIbyebye
Feb 23, 2016 03:36 PM
EVO 4 life
Oct 28, 2015 07:59 AM
RS200
Oct 1, 2015 07:27 AM
tim85851
Jan 14, 2012 07:34 AM
Ree
19
Feb 13, 2004 09:05 PM
