Injectors
Old Feb 2, 2011 | 07:41 AM
dan08's Avatar
Injectors
I current have precision 1000cc injectors and was wondering if maybe I needed 1200's when i install the fp red.
Old Feb 2, 2011 | 07:54 AM
EVOMIZ's Avatar
1000cc is good for fp red
Old Feb 2, 2011 | 08:03 AM
dan08's Avatar
what about for e85?
Old Feb 2, 2011 | 08:07 AM
EvoVIIIFL's Avatar
Originally Posted by dan08
what about for e85?
hell no
Old Feb 2, 2011 | 08:09 AM
dan08's Avatar
Originally Posted by EvoVIIIFL
hell no
Thats what I thought Just wanted to confirm before I sell them.
Old Feb 2, 2011 | 08:10 AM
EvoVIIIFL's Avatar
LoL.. ya I'm personally getting some 2250's here soon
Old Feb 2, 2011 | 08:12 AM
dan08's Avatar
Any ideas of what I should look into gettting before i have to go double pumper?
Old Feb 2, 2011 | 08:16 AM
EvoVIIIFL's Avatar
Considering what you have.. you might as well get it man.. it helps raise the fuel pressure exponentially and I've had mine now going on 5ish years.. nothing more you can really do fuel wise other than double pumper and unless you got a upgraded fuel rail..stock FPR works fine.. its what I use lol
Old Feb 2, 2011 | 08:18 AM
dan08's Avatar
I just didnt want to go dumble pumper till I absolutely have to. But I know its gotta be done sooner or later.
Old Feb 2, 2011 | 08:21 AM
EvoVIIIFL's Avatar
Well only thing you can upgrade is the fuel rail itself judging from your mod list in your sig. After that its the double pumper is your next and final mod for fuel aside from the injectors. and if you want a upgraded FPR.. but like I said..stock works fine and no more $ expense
Old Feb 2, 2011 | 08:24 AM
dan08's Avatar
Sounds good.
Old Feb 2, 2011 | 08:28 AM
dan08's Avatar
A question i also had is on the double pumper, what size line to i need for the feed and return?
Old Feb 2, 2011 | 08:50 AM
EvoVIIIFL's Avatar
It works with the factory lines very easy install
Old Feb 2, 2011 | 09:04 AM
dan08's Avatar
I know buschur has one that uses stock lines but then other ones requires different size fuel lines. Must be if you upgrade the lines?
Old Feb 2, 2011 | 10:00 AM
EvoVIIIFL's Avatar
I guess so unless they require you too do so... which is a PITA from what I've seen/read
