Is it okay??? ( AEM Wideband)
Old Feb 4, 2011 | 03:28 PM
erald01's Avatar
Quick question for you guys, finished installing the wideband all the wireing and everything besides plugin in the sensor. (I am taking off the dp to weld on the o2 bung) I was gona start the car and let the battery charge for a bit, is it okay if I start the car with the sensor not plugged in, but all the rest of the wiring connected? I dont want to burn the sensor or make it go bad by not bein plugged in when the power is on!!
Old Feb 4, 2011 | 04:56 PM
erald01's Avatar
Old Feb 4, 2011 | 05:11 PM
chinto's Avatar
if you have the dp off and letting the car run / warm up charge the batt what ever you want to do with it.. you will most likely melt the plastic under the hood..
i know this when i had my first evo i had to trouble shoot a no power / boost issue that eneded up being a clogged cat. i ran my car with the down pipe un hooked and as long as the car was moving i was fine i got stuck in some traffic and some of the spark plug cover and the cam belt cover melted.
Old Feb 4, 2011 | 05:14 PM
erald01's Avatar
No the dp is still on the car, i will be removing it this weekend, i just wanted to start the car one more time before i remove it. I just dont know if its okay for the wideband sensor to be powered on without reading any exhaust flow.
Old Feb 4, 2011 | 05:19 PM
03evo8racer's Avatar
I think you will be fine if you don't let it run for longer then 5-10 min or so. I had started my car with out the wide band sensor plugged in and the sensor works fine.
Old Feb 4, 2011 | 05:28 PM
erald01's Avatar
^^^well i kind of want to let it run for more than 10 min so the fluids get hot enough, the battery gets a nice charge.
Old Feb 5, 2011 | 08:22 AM
erald01's Avatar
anyone else have an input?
Old Feb 5, 2011 | 08:38 AM
RyuEvoIX's Avatar
Aem wideband sensor not plugged into exhaust with power= ok
Aem wideband sensor plugged into exhaust without power= not ok
Old Feb 5, 2011 | 08:52 AM
erald01's Avatar
thanx Ryu thats what i was looking for.
Old Feb 5, 2011 | 11:16 PM
My03evo's Avatar
Yea what Ryu said, it needs power because it powers an internal heater in the sensor and without it won't burn off crap it needs burned off and if enough it will affect the sensor readings...Even says to avoid this on the AEM site. Could always just throw a battery charger on it if you're worried about the battery getting weak
Old Feb 6, 2011 | 12:52 AM
MechTech's Avatar
Put a charger on the battery
johnjonfenomeno
178
Jan 7, 2026 09:18 PM
Femi
AEM EMS
23
Apr 5, 2016 11:38 AM
robertg
62
Feb 18, 2016 03:28 PM
fi8tzer0
Nov 23, 2015 11:15 PM
Anthonytad
Lancer Engine Tech
15
Aug 24, 2011 06:52 PM
