Where's this *&%$ thing go?
Old Feb 5, 2011 | 05:43 PM
GrnEVO's Avatar
I already had to doa lot of work because the car I bought seemed ok then I got some crazy stuff going on and after some investigation and diagnosis of my FP Red, she was done. So I'm taking things out and apart and I notice a hose that I had no idea where it was SUPPOSED to be connected to. I'm assuming the TB but it wasn't connected. Can someone tell me where it's supposed to go to.
Old Feb 5, 2011 | 05:55 PM
wizzo 8's Avatar
That's the fuel vapor purge valve hose. Goes to I/M
Old Feb 5, 2011 | 06:03 PM
milford's Avatar
it could be there unconnected because someone did a evap/charcoal canister delete..if this is the case they capped the inlet nipple for this on the manifold..if not you prob had a bad vacuum leak didn't you.
GrnEVO's Avatar
thanks, now I just have to figure out which nipple it goes to. Also, why don't I have any hoses hooked up to my TB?
Old Feb 5, 2011 | 06:06 PM
GrnEVO's Avatar
vac at idle has been around - 13 and everything seemed ok
Old Feb 5, 2011 | 06:12 PM
psphinx81's Avatar
if you dont have EGR/evap crap in your car it does nothing, you can just take it off. i leave mine uncapped and just let it vent
Old Feb 5, 2011 | 06:19 PM
Steed77's Avatar
Here is a thread about that mod.
https://www.evolutionm.net/forums/ev...-canister.html
Just make sure, if you are using the OEM intake manifold, CAP the end in the IM. (leave the line in your picture vented, don't cap it)
Old Feb 5, 2011 | 06:20 PM
wizzo 8's Avatar
TB nipples are for coolant. Leave those capped off unless you live in negative temperature climate year round
Old Feb 5, 2011 | 07:01 PM
GrnEVO's Avatar
I'm new Evo's and different mods (even DSM) so I'm still learning but I appreciate all the help so far.
