Idk what's happening?
Old Feb 11, 2011 | 11:16 PM
MMMills89's Avatar
Ok so this is my first turbo car so somethings idk how to diagnose myself yet, with that being said my car when it hits full boost or close to it even somewhere about 22lbs it cuts in and out sounds kinda like a drum roll.... Idk how else to explain it lol it seems to me like a lack of fuel but then again idk because it will hit 25 lbs then just pop like that till it tapers to about 20 or so and then smooth out and increase speed and it just recently started... If u have any ideas that would great and thanks in advance
Matt
Old Feb 11, 2011 | 11:29 PM
dRiFtInG_mR's Avatar
got a video?
Old Feb 11, 2011 | 11:33 PM
dscevo8's Avatar
Ive had that same sound...sounds kinda like a machine gun sputter? I replaced my plugs, gapped them to .22, and bought a new battery. Problem fixed. Dont know what one did it tho lol Granted, right before this was happening an injector seal had popped out too. Are you tuned? Could be something as simple as fuel cut or boost cut.
Old Feb 12, 2011 | 01:39 AM
MMMills89's Avatar
Yeah it was all done when I got the car it is tuned at 25 lbs I have rc750 cc injectors I was going to change the plugs this weekend and try that someone said could be boost leak but I thought I wouldn't hot full boost like that so if the plugs didn't work I was thinking upgrade fuel pump and go with some fic 1000 cc injectors and do tune but idk I'm new to the turbo world and don't wanna waste any more money than I have to if its not the problem?!
MMMills89's Avatar
Originally Posted by dRiFtInG_mR
got a video?
No video I guess I could make one this weekend and try to figure out how to put it up here lol
Old Feb 12, 2011 | 05:16 AM
cij911's Avatar
Boost leak....
Old Feb 12, 2011 | 06:22 AM
MMMills89's Avatar
Originally Posted by cij911
Boost leak....
I thought that too but wouldn't it happen all the time not only under hard boost? I was going to look into that more and like five of my buddies told me I was wrong that's why I made a post
Old Feb 12, 2011 | 07:09 AM
MattC28's Avatar
I would check boost leaks and your spark plugs. Start there. Could be a slight leak that only happens when under high pressure.
Old Feb 12, 2011 | 07:10 AM
MattC28's Avatar
Oh, and do you have a stock blow off valve, if so is it the black plastic one?
Old Feb 12, 2011 | 08:22 AM
cfdfireman1's Avatar
Toss a new set of plugs in her. NGK BR7ES gaped at about .023" should do it and it won't cost you more than $10.
Report back.
Old Feb 12, 2011 | 08:32 AM
justincase's Avatar
Had the same problem when I upped my boost, it was the plug gapping
Old Feb 12, 2011 | 09:08 AM
MMMills89's Avatar
Thanks for all the help guys I'm at the auto show right now in Chicago but when I get home I'm going to do plugs first thing then go from there I'll let everyone know thanks a lot much appreciated
Old Feb 12, 2011 | 09:09 AM
raasfaas's Avatar
Has the car been tuned? That sounds like boost cut...did they up the limit?
MMMills89's Avatar
Oh and no I have a turbo xs bov
Old Feb 12, 2011 | 09:15 AM
raasfaas's Avatar
have you tried tightening up the bov?
