engine noise
Old Feb 13, 2011 | 07:00 PM
barneyb's Avatar
So, are you saying it is fixed? Do you still have noise?
Old Feb 13, 2011 | 07:02 PM
Spanishevo's Avatar
lifters have been changed, i thought they caused the problem but i drove the car about 2 hours after they were installed and the noise started up again.
Old Feb 13, 2011 | 07:22 PM
barneyb's Avatar
Well, if it went away for awhile and now it is back, in my opinion, it has to be lifters. Anything else would have continued to make noise the entire time.
Are you running on old or fresh oil?
Old Feb 13, 2011 | 07:26 PM
Spanishevo's Avatar
yea thats wut i was thinking but like i was saying before, earlier today i changed the lifters from the original lifters to the zero tick lifters from power division and i thought that wouldve fixed the problem because the noise coming from the lifters made sense to me also because the sound didnt stay, only during acceleration but i have not changed the oil yet but i plan to soon
Old Feb 13, 2011 | 07:27 PM
Spanishevo's Avatar
do u think the sound will just go away or should i redo the lifters?
Old Feb 13, 2011 | 07:38 PM
barneyb's Avatar
A DSM I used to drive would go about 1800 miles on an oil change and then the oil would turn black and the lifters would start ticking. It turns out I was using a brand of bad oil with little detergent and the engine was dirty. In 1800 miles the filter would plug and bypass. Later this well known oil company came out with "new improved oil with more detergent".
So, anyway, lifters like clean oil.
If you have cams in the car, sometimes lifter tick can be hard to get rid of.
Other than that, the only thing I can think of is a balance shaft bearing. But those will only make noise when the engine is hot and revved hard. Balance shafts turn at twice engine speed so they really buzz - a noise with four times the frequency of a lifter.
Old Feb 13, 2011 | 07:42 PM
barneyb's Avatar
Since you have already driven it for two hours, short of trying the Service Manual cleaning proceedure, I don't know what else you can do. I'd suggest changing oil and driving some more.
Old Feb 13, 2011 | 07:46 PM
gsr0801's Avatar
I have the same noise and two different tuners told me it was my lifters. I use 20w50 oil in my car because Im using Meth and the lifters sounds loud at first but a few miles in its not as loud. Try also different weight oil.
Old Feb 13, 2011 | 08:55 PM
Spanishevo's Avatar
allright thanks for all the info guys imma change the oil hopefully soon one thing i forgot about is that my oil cap had broken a couple days ago and my oil fell all out and when i put new oil in, what i had at the time was mobil 1 and castrol syntec so i mixed them but im going to use royal purple 10w30 when i get the change so maybe that could have something to do with it and i do have cams, i have 272 cams from gsc power division they are jun style cams
Old Feb 15, 2011 | 12:09 PM
Spanishevo's Avatar
would bent valves cause that same noise?? the engine has around 130k miles on it
Hassan
103
Aug 5, 2023 11:37 AM
Hileyrolen
May 10, 2016 01:01 AM
OZRally462
Lancer Engine Management / Tuning Forums
Jul 29, 2014 05:53 AM
ecl27
Dec 9, 2011 09:46 AM
icole
Oct 14, 2009 10:28 AM
