Draining fuel tank...?
Old Feb 14, 2011 | 05:12 AM
Phoenix*'s Avatar
Hello...
Is there any quick way to drain a full fuel tank from an Evo 8...?
Other than going through the fuel pump entry...
Any help would be appreciated.
Thank you.
Regards,
Phoenix
Old Feb 14, 2011 | 05:23 AM
Gary@MellonRacing's Avatar
There is a bolt underneath the gas tank that u can remove and the fuel will come out , please very careful when doing stuff with fuel , i always have a Fire extinguisher on hand when working with fuel , and i always disconnect my battery when working with fuel also , keep it safe
Old Feb 14, 2011 | 09:17 AM
boostedwrx's Avatar
Thats good advice to disconnect the battery. I usually do that too and make sure no one lights a cig around me
Old Feb 14, 2011 | 09:22 AM
03whitegsr's Avatar
You can probably get a metric to hose barb fitting to help out. Other wise, the fuel wants to run across the bottom of the tank making it a PITA to catch it in a container.
Old Feb 14, 2011 | 12:51 PM
evo8john's Avatar
and it likes to pull off the undercoating on the bottom of the tank so you may want to grab a can of this to respray it when your done draining and the fuel dries
Old Feb 14, 2011 | 04:02 PM
turbolarry's Avatar
This is the only way I know how to do it;
http://www.evotuners.net/forums/f25/...-gas-tank-172/
Pull and plug the retun line and attach a section of hose into a container.
Old Feb 17, 2011 | 12:07 AM
Phoenix*'s Avatar
Thanks for your reply guys.
Much appreciated!
@ Gary@MellonTuning
This gas tank bolt easily accessible from underneath the car...?
@ turbolarry...
I think your method will work best...
In the process of pulling out the motor...
Plenty room within engine bay now...
Just don't want to fuel to age in the tank, and cause issues once rebuild is done...
Old Feb 17, 2011 | 03:38 AM
evo8john's Avatar
You dont even have to jack the car up to drain the tank using the drain bolts. Its by far the easiest way.
Old Feb 17, 2011 | 06:58 AM
03whitegsr's Avatar
Agreed
Just get a fitting other wise the fuel goes every where. I THINK it is 10mm x 1.25 but I could check tonight as mine is already empty.
Old Feb 17, 2011 | 07:20 AM
ok , ive used both ways to drain fuel ,
1. Safety first
2. Bolt underneath , really took all the fuel i had in the tank ...
3. the fuel line in the motor ... took fuel out , but still left fuel in my tank
4. play it safe =)
Old Feb 17, 2011 | 10:05 AM
Phoenix*'s Avatar
Ok, I'll make use of the drain plug...
Thanks gents...
Let me go try find it...
Old Feb 17, 2011 | 11:16 AM
MasterNater's Avatar
There's actually two bolts on the bottom of the fuel tank. One for each side of the tank. If I remember correctly, if you run the tank almost to the point of being empty, the majority of the fuel will be on the driver's side. Last time I did it, I think I still got a small amount of fuel from the passenger side as well.
Old Dec 13, 2012 | 07:09 PM
silverevo05's Avatar
any problems with leaking after you put the bolts back on?
was the 10mm x 1.25 the correct fitting?
Thanks
Old Dec 18, 2012 | 05:12 PM
^ Bump is this the right size then???
Old Dec 21, 2012 | 05:14 PM
Can I go through the passenger side tank in the car under the bakc seat, or do I need to relieve pressure there as well
