Smallest 4" air cleaner for 600-650whp
Old Feb 16, 2011 | 02:02 AM
bsh's Avatar
bsh
Hi
Looking for a small 4" air cleaner for 600-650whp. I do run a pretty big KN now, but want to reroute the air filter and need a smaller one. It must have 4" inlet.
Any recommandations?
Thanks
Old Feb 16, 2011 | 05:05 AM
240Z TwinTurbo's Avatar
Rule of thumb:
Determine desired flywheel hp, multiple by 1.5, and you get cfm required.
700hp(flywheel) x 1.5 = 1050cfm
You will probably need at least a 9" K&N.
Old Feb 16, 2011 | 06:06 AM
bsh's Avatar
bsh
Thanks, but I meant 4" inlet flange. It seems like KN doesnt give any hp/flow info on the filters...
I could not find any 4" Amsoil filters on Amazon.
What filters are the 600 whp guys running when minimum space are available?
Old Feb 16, 2011 | 06:48 AM
ihockey1's Avatar
could try the perrin, you would need a 4.5 to 4 adapter tho, its fairly compact and i would say it flows pretty well seeing as its just foam over the end of a pipe
Old Feb 16, 2011 | 06:57 AM
psphinx81's Avatar
buschur sells one, its what i use
EvoDom's Avatar
I have a 4" k&n on my car and I made over 600
Old Feb 16, 2011 | 08:18 AM
Roger, my reference to 9" is the total length of the filter that is assumed to be flanged for a 4" inlet. While K&N doesn't post flow specs you can call and they make a quick calculation. Their flow numbers relfect 1.5" H2O pressure drop and here is what I found...
K&N RE-0870 (901.67cfm) - 9" long cone filter
http://www.knfilters.com/search/prod...x?Prod=RE-0870
K&N RE-0860 (1202.23cfm) - 12" long cone filter
http://www.knfilters.com/search/prod...x?Prod=RE-0860
With that said people will post they have achieved 600hp@wheels with smaller filters. This may be true, but it is a restriction as compared to a properly sized filter. Same argument you see when English Racing reports 30-40hp@wheels gains when removing the MAF and switching to speed density with no filter.
I think you get the idea, running a smaller filter will hold back power.
Old Feb 16, 2011 | 09:35 AM
apagan01's Avatar
EA 4560, we have a buch of them
Old Feb 16, 2011 | 09:46 AM
Jrod@Buschur's Avatar
https://secure.buschurracing.com/cat...oducts_id=1548
Old Feb 16, 2011 | 09:51 AM
The Amsoil EA 4560 is a replacement for the K&N version RU 4740:
RU4740 - 582cfm @ 1.5" H2O
I am not sure how much more flow you get from the Amsoil version listed above.
Old Feb 16, 2011 | 01:54 PM
bsh's Avatar
bsh
Thanks all
Jrod
How much hp is it rated to? Looks very interesting.
Old Feb 16, 2011 | 02:24 PM
apagan01's Avatar
There was a test conducted and ASMOIL came in 2nd out of over 5 filters, in filtration and flow.
many folks running it, with small and big turbos
https://www.evolutionm.net/forums/ev...t-results.html
Old Feb 17, 2011 | 07:13 AM
Thanks all
Jrod
We had that filter custom made for us from a BIG name filter manufacturer.
Its the same filter that we run on the BAD BISH... so we know its good over 700whp on our Mustang Dyno.
Old Feb 17, 2011 | 11:20 PM
bsh's Avatar
bsh
Thanks Jrod
That is more than enough for me I will place an order in your webshop.
Thanks
Old Feb 18, 2011 | 07:37 AM
Thanks Jrod
Thanks
You're welcome! Thank you for your order.
Glad I could help!
