not building boost during boost leak test
Old Feb 16, 2011 | 04:24 PM
evokid511's Avatar
so im trying to do a boost leak test and i can not build any boost, i have the motor at TDC and still nothing... any ideas?
there is some boost leaking out of the exhaust tho, so idk whats going on
builds air in system but is venting to exhasut somehow
Old Feb 16, 2011 | 04:37 PM
bbyevo8u's Avatar
do you have a boost controller? if so you have to cap off one of the two hoses, or just cap them both
Old Feb 16, 2011 | 04:38 PM
evokid511's Avatar
everything is set up correctly as far as capping lines and things like that but im really looking for why boost is escaping out of exhaust
Old Feb 16, 2011 | 04:41 PM
tscompusa2's Avatar
turn crank a bit more.
Old Feb 16, 2011 | 04:45 PM
Tuxevo's Avatar
Is your crankcase vent tube running into your intake and your pressurizing at the maff? If so there your issue. Pressurize at the turbo inlet.
Old Feb 16, 2011 | 04:52 PM
RazorLab's Avatar
90% chance EGR vac line is off
Old Feb 16, 2011 | 05:18 PM
evokid511's Avatar
Egr it was thanks guys
Old Feb 16, 2011 | 05:29 PM
RazorLab's Avatar
Glad that helped.
Old Feb 16, 2011 | 05:38 PM
sparky's Avatar
Originally Posted by razorlab
90% chance EGR vac line is off.....
Impeccable! Really a nice call.
Old Feb 16, 2011 | 05:40 PM
RazorLab's Avatar
I've done so many boost leak tests I could do them in my sleep. Some early mornings I probably have... :-/
Old Feb 16, 2011 | 07:22 PM
evokid511's Avatar
that has been driving me crazy for about 5 months and 3 tests haha thank you for finally solving the question, that line was blown completely off the nipple
Old Feb 16, 2011 | 07:29 PM
tscompusa2's Avatar
zip tie everything! zip ties are your friend. on my car i even super glue the nipple before i put the vac line over stuff since stuff starts to leak past 35psi where it dont around 25-30.
specifically zip tie the fuel pressure regulator vac lines for safety.
Old Feb 16, 2011 | 07:34 PM
BoxerSix's Avatar
old school trick to backup the zip ties....shoot a little hairspray on the end of the hose and slide over the fitting or vacuum nipple then tie of with a zip tie. when it dries it'll glue the line on with a temporary bond that can be remove with some force, but won't blow off under high boost.
works great on couplers and orings too in a pinch if needed in such an application.
Old Feb 17, 2011 | 04:54 AM
evo8john's Avatar
I use this on all my couplers too. Hairspray is like magic! T-bolt clamps help too
Old Feb 17, 2011 | 07:37 AM
evokid511's Avatar
hairspray works awesome, carry a bottle in the car with me just incase... my hair messes up hahaha but yeah the FPR as leaking a little also, some zip ties fixed it nicely
