PTE 6262 Journal - proper oiling?
Old Feb 20, 2011 | 10:08 AM
badev0's Avatar
I have searched and have not had any luck to this question.
I want to know what would be a proper oil feed setup for a PTE 6262 journal bearing. Head or oil filter housing? Restrictor or no?
Thanks
Old Feb 20, 2011 | 10:19 AM
n2oiroc's Avatar
Precision always says no restrictor, but a lot of guys have problems with oil blowing past the seals without one.
Old Feb 20, 2011 | 10:29 AM
BigT's Avatar
As per PTE, you should feed from the OFH with a -4 line. The head doesn't provide enough pressure and volume of oil for a JB turbo. However, if your motor is producing upwards of 80psi of oil presssure, I would look into some type of restrictor. Remember, this will be a relatively large restrictor vs a ball bearing turbo.... something along the lines of a .8 or .75 size fitting. Some have said to run a -3 line as another option as well. Its going to be some kind of trial and error. Start with a -4 line. Usually, you can see a little extra smoke out the exhaust with too much oil pressure. If so, try a restrictor or switch to a -3.
Old Feb 20, 2011 | 10:47 AM
badev0's Avatar
Thank you for the information.
Right now I am running FP's oil feed line for my journal bearing holset with the .030" restrictor (black unit) which I just read is better for ball bearing turbo's not journal bearing turbo's (probably why there's some smoke)
Anyways, I will try just a -4an with the 6262 and see how that goes. Do you know where I can buy a .75 restrictor?
Thanks
Old Feb 20, 2011 | 12:22 PM
BigT's Avatar
Ebay is your friend.
the 6262 chra fittings are the same as garret.
Old Feb 28, 2013 | 07:54 PM
Howulikemyevo's Avatar
Does anyone know what size oil inlet that connect to the turbo from the oil feed line? And if i used the 3an lines, does it fit into both the cars' head and into the turbo? Or do i have to convert both of them to make it fit the 3an lines?
Old Feb 28, 2013 | 09:22 PM
I bought a new oil feed line but its 102cm. Can someone tell me if it is a 4an or 3an line? And it comes with* Oil feed T6 Aluminum flange kit with 1mm Restrictor. Its the 1mm a proper size restrictor for my jb pte 6266 turbo? Please help
staticstance
Nov 29, 2015 07:55 AM
nesty2
Sep 1, 2014 05:54 AM
Randal
Sep 29, 2013 04:41 PM
artyturbo
Jul 4, 2013 08:20 AM
JDM EVO PANAMA
Jan 15, 2011 02:37 PM
