PTE 6235R turbo ???? vs 6262
Hello since usually the people who read this section are the people who know since a lot of tuners read this part of the forum.
I got a turbo kit it came with a blown turbo the seller advertised it as a blown turbo he told me it was pte 6262 which was fine. When I send it to PTE though they tell me its actually a 6235R not a 6262. Journal Bearing at PTE are only 200 to fix however since this was ball bearing it was around the 1000 USD ball park to fix.
What can I expect from this turbo and what are the advantages and disadvantages?
I see it kind of the inbetween of a 6262 and an HTA
what numbers can I expect on my 2.0 and spool characteristic.
GSC 274 S2
Valve Springs and Valves Ferrah
ETS 4"
Sparktech
1200cc
DW 300 fuel pump (im hoping to be one of the first with this)
Forged internals 2.0
Ported and polished head
93 oct
Evo 8 ecu hopefully tuned by a good tuner
GSC 274 S2
ETS 4"
Sparktech
1200cc
93 oct
We have a Evo 9 running a similar spec:
Motor Built by Steve Clark (9000rpm)
-Crower Rods
-CP Pistons
-Balance Shafts removed
- Ported and flowed head
- BC valve springs & retainers
- GSC S2 Cams
- ETS PTE6235RSP Turbo Kit
- Greddy FMIC
- Custom 3inch boost pipes
- HKS 3inch Exhaust
- PTE 1200cc injectors
- Haltech Platinum Pro ECU
- Spoolinup COP
Makes equivalent of about 700hp Dynojet
-Crower Rods
-CP Pistons
- GSC S2 Cams
- Greddy FMIC
- HKS 3inch Exhaust
- Spoolinup COP
-Crower Rods
-CP Pistons
- GSC S2 Cams
- Greddy FMIC
- HKS 3inch Exhaust
- Spoolinup COP
-Crower Rods
-CP Pistons
- GSC S2 Cams
- Greddy FMIC
- HKS 3inch Exhaust
- Spoolinup COP
I dont want numbers that high but on what type of gas?
The 6262 is superior if you are comparing the two. The turbonetics F1 turbine wheel is larger on the inlet side(inducer) than the garrett 35r turbine. Which explains why its a tad laggier but offers better top end flow.
basically w/ the exact same compressor wheel... the 35r turbine will spool better. The F1 (eg. 6262) will have slightly better top end potential w/ a marginal lag vs the garrett wheel.
FS[Northeast]: PTE 6262 cea 2 ball bearing
gigitalon
Feb 1, 2018 03:02 AM
FS[Northeast]: PTE 6262 V-band BALL BEARIING FS
Skidonner90
Aug 1, 2016 11:02 PM
aronjaskim
15
Jul 18, 2010 01:13 PM
From 3 to E
Apr 27, 2010 08:59 PM
