oil cooler lines
Old Feb 20, 2011 | 06:01 PM
degin219's Avatar
oil cooler lines
any one know the fittings size so i can make new lines, going to braided lines. or maybe a write up?
If not I will try and post it after I do it next week.
thanks.
Old Mar 19, 2011 | 05:20 PM
GrnEVO's Avatar
I'm trying to find out the same thing... let me know if you find anything
Old Mar 19, 2011 | 07:56 PM
Teal2nnr's Avatar
STM would know, since they build an aftermarket cooler.....actually there are several companys on here that offer and aftermarket oil cooler....one of them will surely know.
Old Mar 19, 2011 | 09:39 PM
RSMike's Avatar
M18 -> AN10 for oil filter housing.
then AN10 lines and fittings
Old Mar 20, 2011 | 01:19 PM
GrnEVO's Avatar
Thanks Mike, I found the info yesterday evening and hadn't made it back here to tell the OP yet.
Old Mar 20, 2011 | 03:47 PM
RSMike's Avatar
was i right? lol
it's been a while since i bought those fittings
Old Mar 20, 2011 | 07:07 PM
Turboshrek's Avatar
M18X1.5 try Summit p/n 670561
Old Mar 20, 2011 | 11:50 PM
degin219's Avatar
All connections the same size for the 2 lines?
Old Mar 21, 2011 | 09:26 AM
Turboshrek's Avatar
I'm not sure. I only looked into the thread size on the oil housing b/c I was making a custom oil cooler kit and used a after market cooler. I would guess they are the same on the OEM.
check out pg. 12-6
http://carbon-based.net/_pdf_/mitsu_...0003900-12.pdf
For ref: Same part number same thread!
Old May 12, 2015 | 06:18 PM
ezzey's Avatar
Bringing back from the Dead, so M18 for the oil filter housing side, evo8. That's not NPT is it? Just straight thread? Can someone confirm?
Im confused, because i bought the STM oil cooler kit with the hoses and fittings, and when i went to put the fitting into the oil filter housing, its to small by a size. The one i pulled out from my oil filter housing was bigger, and NPT, the one STM sends out is smaller and Straight thread. I'm confused.
Gonna go buy another at a local store, but not sure if i should get M18, straigh thread/ npt? im lost.
David
Old May 12, 2015 | 07:35 PM
doubleSUSTANON's Avatar
David
U took of wrong ones . Here is the instruction, hope it helps.
http://www.maperformance.com/tech/ma...llation-guide/
Old May 15, 2015 | 02:05 PM
ezzey's Avatar
Thanks.
And i didnt pull out the wrong ones. I figured it out, and the previous owner of the car probably snapped a fitting in there, redrilled and tapped to 1/2" NPT. It's all figured out now. Thank you.
Old Jun 9, 2015 | 08:43 PM
wizechef's Avatar
I searched for this in summit I couldn't find it
Old Jun 9, 2015 | 09:56 PM
http://www.summitracing.com/parts/fra-461018/overview/
http://www.summitracing.com/parts/rus-670560/overview/
http://www.summitracing.com/parts/ea...kerl/overview/
Old Jun 10, 2015 | 01:53 PM
wizechef's Avatar
Thank you very much
