Damn check engine light!!!
Old Dec 12, 2003 | 04:02 PM
AltezzaRoku's Avatar
About a month ago my 'service engine soon' light came on. A few days later, it went off. Now, after about a month of it being off.,.. it comes back on again! WTF.
BTW..
1. my car has been running fine the entire time.
2. Only mod i have is hks type 1 TT.
has this happened to anybody else?
DynoKing's Avatar
In Timeout
Pull the code....
Old Dec 12, 2003 | 04:04 PM
SilverEvo8owner's Avatar
check your gas cap
Originally posted by SilverEvo8owner
check your gas cap
true that!
Old Dec 12, 2003 | 04:50 PM
MANGOOK's Avatar
Mine through a light also and somehow the gas cap had become loose. Good Luck
Chris
Old Dec 12, 2003 | 04:59 PM
WINSTON's Avatar
Registered User
Ditto, check that cap!
Cheers,
Winston
Old Dec 12, 2003 | 05:02 PM
MalibuJack's Avatar
Same here.. Turned out the gas cap was loose.. Check that first before you get concerned..
Old Dec 12, 2003 | 07:14 PM
Thoe99's Avatar
Make sure you the gas cap clicks about 4-5 times when you close it.
Old Dec 12, 2003 | 09:33 PM
I tried the gas cap.... didn't work either. :ugh:
Old Dec 13, 2003 | 12:23 AM
Evo2003.5's Avatar
I assume you tapped into the ECU for the wiring? Check the connection and make sure nothing's disconnected. If there's a short, the system might throw a code...
Evo2003.5
Old Dec 13, 2003 | 06:17 AM
TrippinFlip214's Avatar
Take out the turbo timer, reset the ECU. Then if the engine light comes back take it to the dealer.
Old Dec 14, 2003 | 01:17 AM
TRDHarrier's Avatar
around 200 miles ago, my CEL came onand 200 miles later, it went off. Asked Mitsubishi WTF did my CEL go on??? My gas cap has been tight every single time. Only mods are Dynoflash, HKS RS intake, Cusco Oil Catch Tank, HKS DP, UR 3" Cat, HKS CB, and some electronic mods. O2 sensor was placed at a very accurate position. Didn't know why. They say sometimes it reminds you for oil changes. I have changed the oil at 1K, 4K, and now 7K. Next will be 10K.
Old Dec 14, 2003 | 05:17 AM
WrX Kila's Avatar
Gas cap and Reset Ecu.
Old Dec 14, 2003 | 11:35 AM
WILDMAN's Avatar
Just take the CEL bulb out!
Old Dec 14, 2003 | 11:36 AM
WILDMAN's Avatar
I was just kidding, I agree with these guys. If the cap don't work I would go with TrippinFlip.
