Grimmspeed MBC
Old Apr 22, 2011 | 12:30 PM
Boosted Tuning's Avatar
Originally Posted by nightwalker
I would suggest testing the Perrin/Buschur MBC v.s. this one. I ran a Hallman for a long time, and just switched to the Perrin. Boost builds faster and held better up top with the Perrin.
Buschur also stated in a thread that he saw gains switching from a Hallman to his (Buschur MBC is a Perrin copy)
I have the FORGE MBC on both my cars. I will be testing the grimmspeed on both car.
I have used the hallman before, so I have some experience with it.
I dont really like the perrin/BR inline design. Regardless, If someone wants to send me one. Ill include it in the test.
Also, if someone wants to sends me an hallman, I can include that in the test too.
Matter fact, if people wanna send various MBCs to me, Ill test them all.
And Ill ship them back when done with them.
Old Apr 22, 2011 | 12:31 PM
Originally Posted by GrimmSpeed
Yes you got it!! Sorry it took a couple days extra, but I wanted it to be perfect for you!! Thanks so much.... Eagerly awaiting your thoughts!!!
Will
Yeah, thanks. The install kit looks great and complete. Im looking forward to testing this. First comes testing on the EVO, then Ill be doing testing on the Suby.
Thanks again
Old Apr 22, 2011 | 12:53 PM
GrimmSpeed's Avatar
Thanks again
Yeah for sure!
Just so everybody knows we don't have any willie-nillie claims left and right, just tried and true. If you are a professional tuner or have a shop and you doubt us, put us to the test!
Will
Old Apr 23, 2011 | 12:39 AM
nightwalker's Avatar
I don't see it in the picture, but does this MBC have a bleed hole like the others?
This is the thread where Buschur mentions the MBC change
https://www.evolutionm.net/forums/ev...27-ft-lbs.html
I'm all for new and improved MBC's. Not a fan of solenoids or EBC's.
Old Apr 25, 2011 | 07:26 AM
GrimmSpeed's Avatar
Yep! In fact it does have a bleed hole. We actually went through extensive testing with different sized holes to get it perfect!!
Will
Old Apr 25, 2011 | 11:53 AM
JdmSyndicate's Avatar
hey guys,
this may be a noob question but I just got this boost controller put on my car and I have a couple of questions. I had a Greddy Profec B boost controller on my car for almost 2 years now. The EBC was working great and I had no issues. I went to AWD Motorsports this past weekend to get an ACT clutch installed and while the mechhanic was removing some parts to get access to my clutch, he damaged one of the wires from the boost controller harness when he unplugged it. This led to my car running on wastegate pressure whenever I floored it which was around 10 psi. Realizing this issue the following day, we decided to put this MBC on the car to get her running correctly. The MBC works great and I'm now back to my old psi setting of 24 psi. My issue is that when I had the greddy, my wastegate would begin to open around 10 psi. I can confirm this because I have an O2 Dump and the car begins to get much louder once this occurs. Now with this MBC I noticed that my wastegate doesn't open until around 22 psi. Is there anyway to fix this issue? I figure since my wastegate is opening later, my acceleration has dropped due to the time it takes for the wastegate to open. Do I need to get a different wastegate to fix this issue? FYI I'm still running the factory turbo setup. Any help would be greatly appreciated. Thanks
Old Apr 25, 2011 | 01:23 PM
sparky's Avatar
Originally Posted by JdmSyndicate
....I just got this boost controller put on my car... when I had the greddy, my wastegate would begin to open around 10 psi. ....with this MBC I noticed that my wastegate doesn't open until around 22 psi..... I figure since my wastegate is opening later, my acceleration has dropped due to the time it takes for the wastegate to open. Do I need to get a different wastegate to fix this issue?....
If the WG flapper valve stays on its seat and doesn't start to lift until 22# and furthermore, it is holding your target boost level steady w/no boost creep at 24#, then your boost control parameters are just fine. No need to "fix" anything.
To the contrary: Before, with your EBC programmed as it was, the WG was opening prematurely and you were losing turbo spoolup.
Old Apr 25, 2011 | 04:15 PM
^ Wastegate holds steady until 22 psi? Get it re-tuned and take advantage of the new found power!
Old Apr 25, 2011 | 04:30 PM
sparky's Avatar
Yeah, agreed he should get it retuned.
Old May 6, 2011 | 05:56 AM
RJSP's Avatar
Any update update on the MBC shootout? I currently run the Hallman Pro Rx and like it a lot, but recent reviews of the Perrin/Buschur and the expectations on the Grimmspeed MBC definately got my attention.
Old May 6, 2011 | 12:04 PM
In process of rounding up the MBCs. Should have all of them early next week.
Old May 6, 2011 | 12:39 PM
SyZyGy1394's Avatar
In for results.
Old May 17, 2011 | 01:04 PM
suby2evo's Avatar
fail I just found the new thread sorry!!
Old May 17, 2011 | 01:08 PM
LOL sry bout that. I forgot to update this thread.
https://www.evolutionm.net/forums/ev...ed-tuning.html
RallySport Direct
EvoX 'For Sale' External Engine / Power
13
Jun 29, 2016 02:38 PM
Gtizks
Jun 19, 2016 04:25 PM
VKEVO
Sep 23, 2015 05:53 PM
Daluv
Feb 28, 2012 10:36 AM
kyoo
Jan 22, 2012 04:58 PM
