Should I remove the clutch restrictor?
Old Dec 13, 2003 | 05:06 AM
JT-KGY's Avatar
I just bought the SS clutch line... still debating if I should remove
the restrictor while I'm installing the SS line...
Anyone have bad experience with removal of the clutch restrictor?
I know that it will make clutch grab w/o slipping... but I'm a bit
worry about drivetrain damage like the pop I heard the other
day...
https://www.evolutionm.net/forums/sh...threadid=53971
What do you guys think?
Old Dec 13, 2003 | 05:10 PM
WILDMAN's Avatar
Yep!
Old Dec 13, 2003 | 05:23 PM
5StarSuzuki's Avatar
In Timeout
No. Mitsubishi put it there for a reason. Call up your dealer and ask how much they would charge for a transfer case replacement...
Old Dec 13, 2003 | 05:25 PM
alex_alex's Avatar
i agree. Taking the clutch restrictor plate out is probably one of the stupider things you can do, unless you really don't mind voiding your warranty and paying for a new tranny should it break on you.
The restrictor may harm the clutch engagement, but when you launch and send so much shock to the drivetrain, either the clutch takes it or the tranny does. Ill let you figure out which one's cheaper.
Old Dec 13, 2003 | 06:07 PM
WILDMAN's Avatar
You guys have a point, I just don't dump my clutch like many. It works for me.
Old Dec 13, 2003 | 06:17 PM
alex_alex's Avatar
Yeah bro, as long as youre not dumping it, it won't make much of a difference functionally, but then again, that also means that you wouldn't really be reaping any of the benefits of having the restrictor removed...
But you would still be voiding the warranty on the tranny...
Old Dec 13, 2003 | 06:22 PM
DynoKing's Avatar
In Timeout
I would leave it in, my evo is making about 330ish WHP and it works fine, I can spin all 4 in 1st without dumping it.
Old Dec 13, 2003 | 06:23 PM
WILDMAN's Avatar
True. But with the majority of these modifications we put on our cars you're pretty much screwed anyway. You don't necessarily have to mod the tranny in any way in order to void the warranty. Trust me, I know... I'm a GSM of a dealership.
Old Dec 13, 2003 | 11:12 PM
TRDHarrier's Avatar
Dont remove it. I was thinking for a long long time before. It's there to save ur tranny. When u up ur tranny to a HKS twin plate or similar, YOU WILL NEED A RESTRICTOR.
Old Dec 13, 2003 | 11:34 PM
Zeus's Avatar
Over 14k, restrictor removed... no problems with many, many "launches". The clutch feels like it should have from . If someone is "dumping the clutch" on this little car to launch it, they need a swift kick in the *** anyway. Also, If anyone is so got damned worried about the "warranty" save it like the rest of the "honest" people here on this forum.
Sorry, the rant was for all these people with "experience" of having the restrictor removed and not you JT-KGY. Enjoy your car, and take any advise you get here with a grain of salt... including mine.
Old Dec 14, 2003 | 04:09 AM
memo3's Avatar
I have about 200miles after I removed the restrictor... feels great so far...
Old Dec 14, 2003 | 05:29 AM
WrX Kila's Avatar
Mitsu designed and put that restrictor there for a reason. You dont think MM knows what they are doing. I mean Mistu wanted to keep cost down so they sent the car with a good average exhaust. Other parts we upgrade do not hurt the car (fuel pump cams airfilter) but taking the restrictor out. Again it is there for a reason, you dont want to find out what for. If you do it may be Expensive.
Old Dec 14, 2003 | 08:43 AM
Zeus's Avatar
We all know doesn't make mistakes ... So how long did you have the restrictor out... what problems did you experience?
Old Dec 14, 2003 | 10:00 AM
Tri-Bar's Avatar
Take it out / leave it in, thats really your call,keep in mind however that this mod's been around for a long time with the DSM guys and look how many there are of them.
Old Dec 14, 2003 | 10:11 AM
DynoKing's Avatar
In Timeout
Buschur leaves it in, Al leaves it in, so does Shiv. But what the hell do they know right?
