PIVOT Multiple Data Logger PIVADL
Old Dec 13, 2003 | 11:48 AM
porcupine's Avatar
Does anybody have this unit installed ?, if so how does the A/F value differ from the wideband lamba value. I am thinking of installing an SAFCII maybe 2moro and will be tuning it on the dyno dynamics awd by a tuner, however i might need to adjust the settings here and there after that and this unit looks like it can provide me with a near approximate value of the more expensive lamba unit. It does come with a race spec 4 wire 02 sensor (rather than the 5 wire unit the wideband is typically using).
Check it out at http://www.pivotusa.com/aftuning/adl.htm
Old Jan 10, 2004 | 08:42 AM
templeayb's Avatar
i'm searhing this product on the net. i ask some company if this products can reads @ wideband . But i cant receive any answers.
Now i learn that this product is not avaible now in japan. But still showing on www.pivotusa.com . i cant understand if this product is still avaible.
At the same time this Logger includes the same oxygen sensor with pivot analog a/f meter. as i know analog a/f meter can read @wideband a/f . so maybe this logger can reads @ wideband too.
do you hear any ideas about this product ?
Old Jan 10, 2004 | 05:19 PM
porcupine's Avatar
I also have problem getting accurate information about this particular unit. My local performance shop has a few units for sale and that's where I first learn about these units. The people @ the shop are not sure if these can read at wideband. It does come with a 5 wire a/f sensor. The only thing that demotivate me about these unit is that it comes with a full japanese manual (no english). I tried emailing PIVOT but answer so far. Looking at the manual wiring diagram which is for almost every other car except for the EVO, the connection is pretty simple. The unit taps into (Injector Duty Cycle, A/F Reading, RPM and of course power) from the ECU.Anybody else have used these unit ?
Old Jan 10, 2004 | 09:45 PM
templeayb's Avatar
i sorry about on my bad english because i'm from Turkey .
i understand that you cannot install it because of unavaible wiring diagram for evo's ? . and also pivot dont reply your wiring diagram request via email?
211Ratsbud
Jan 13, 2012 02:16 PM
maperformance
Feb 21, 2009 09:22 AM
TTP Engineering
27
Nov 27, 2007 03:45 PM
HoLeeRay
For Sale - Part Outs
26
Jan 12, 2006 08:02 AM
