Cold vs Hot vs Wet compression #'s
Old Feb 28, 2011 | 02:36 AM
CammedEvo's Avatar
Static voltage.
Car reads 160 across with throttle closed dry/cold/hot
180 across closed throttle and wet.
Cold open throttle car is showing 175-180 gauge is hard to read very accurately plus i was getting tired.. None the less they are close.
Every cyl cold showed a 20psi increase at WOT by adding 1tspn of 10w. Each was very close to 200 if not right at it.. This motor is over 60k old and was built in 06.
Are these cold/dry/wet increases typical? 20psi on a 180psi motor? I'll do a WOT hot dry/wet test tomorrow and get numbers
Also lastly whats started me with this is my #3 plug has been turning a darker color than 1,2,4. Which isn't the normal, i'm leaning tward maybe a injector seal causing a rich situation in just that cylinder. If it helps i'm on e85
Old Feb 28, 2011 | 08:26 AM
cefaln452's Avatar
so at a cold compression test you were reading 160?
Old Feb 28, 2011 | 12:56 PM
CammedEvo's Avatar
175-180 cold/dry 195-200 cold/wet
Old Feb 28, 2011 | 01:16 PM
Inflame's Avatar
I'm at 160psi warm/dry... I think... I don't remember
Old Feb 28, 2011 | 06:54 PM
cefaln452's Avatar
he's at 10:1 according to his sig
Old Mar 1, 2011 | 05:44 PM
CammedEvo's Avatar
i'm more or less wondering what is acceptable or "common" for dry/wet differences..
if your 160 dry what wet?
Alchem1st
Jul 28, 2017 01:15 PM
evo.matt
May 20, 2017 09:01 PM
Seth_Horton92
Feb 9, 2017 07:13 AM
No_Skillz
70
Sep 13, 2016 11:49 AM
sponge bob
Apr 18, 2006 07:41 PM
