Fullblown 1/4 Sputter
Hey guys,
I saw that people have had this problem and I just cant seem to figure it out..checked the siphon and its on correctly..once the needle hits a 1/4 tank it will sputter trying to get into boost..what can it be..its DRIVING ME CRZY..any help would be appreciated. thank you
-Mike
-Mike
im not familiar with the y fitting fix. the two full blowns we have used we just used longer hoses placing the pumps lower in the hanger and never had another problem
Yeah they are pretty much hitting the bottom...the problem is its prob not pulling fuel from the other side of the tank..prob gonna just get the BR dp unless i could fine a fix to this..
umm if you have a adjustable regulator i would drill the siphon and adjust your pressure back down. those are about the only two fixes to the 1/4 problem with the ful-blown. i have had people tell me they welded two fittings on teh bottom of the gas tank and connected them with AN fittings/hose to keep gas connected from both sides. If you do end up selling we use the buschur also or make our own which a buschur is just a better more simple design than teh Full-blown
Igaly1021
Nov 7, 2015 05:18 PM
Miller_x
Jan 9, 2013 05:29 AM
