Engine sputter at WOT?
Old Jul 2, 2009 | 06:35 PM
vxevolutionxv's Avatar
I installed br7 plugs and it ran mint for a while. However now at WOT it starts sputtering hard when it comes into full boost. Also when im just crusing around it will randomly sputter but not like crazy. Like 1 sputter every once and a while. Can anyone help me out?
Old Jul 2, 2009 | 06:38 PM
SEEnoEVO's Avatar
close up the plug gap a little
Old Jul 2, 2009 | 07:43 PM
DBallz's Avatar
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
Also double check for a boost leak too.
Old Jul 2, 2009 | 07:47 PM
diiirk@AwdMotorsports's Avatar
check for leaks. you could also check to make sure that the coil packs are connected good. what are the plugs gapped to and what boost level are you at?
Old Jul 3, 2009 | 02:28 PM
plugs are gapped to 27-28 around there, and im at 20 psi. I just replaced my throttle body shaft seals thats where my major leak was. Other then that im dumb founded...lol
Old Jul 3, 2009 | 08:32 PM
heavens turbo's Avatar
the copper plugs foul out fast. maybe time for plugs. how long you had em?
Old Jul 3, 2009 | 08:33 PM
spdracr's Avatar
gap down to .22
Old Jul 6, 2009 | 12:41 PM
I had the copper for like a little less then 2 weeks. I switched back to iridium and still doin i. Ill try changing the gap c what happens.
Old Jul 6, 2009 | 01:24 PM
TxEvo8's Avatar
narrow the gap, and you should be good to go.
Old Jul 6, 2009 | 02:09 PM
narrowed the gap to 22 and still doin it. I found boost leaks at the lower and upper intercooler pipe. I think it could be causeing it.
Old Jul 6, 2009 | 07:45 PM
Vibrant's Avatar
You could also try swapping the coils out one by one. I had a coil go bad and luckily had a buddy willing to let me try his coils. I too thought it was a boost leak at first.
Old Jul 6, 2009 | 09:37 PM
umm well just to please my friend i did a compression test and i dont think it came out good. 110-#1 / 90-#2 / 125-#3 / 125-#4. What should i be at? and is it my rings or valves how do i know? im pissed
2006GSR
Aug 20, 2016 09:22 PM
Igaly1021
Nov 7, 2015 05:18 PM
Onkar02
Lancer Troubleshooting
Mar 24, 2008 10:02 AM
10SEKNDMR
Nov 11, 2007 10:55 PM
DruMMinStUd06
10
Jun 13, 2007 08:26 AM
