Stupid sputter. At around 2500-2900 rpm
Old Jan 4, 2013 | 09:03 PM
Miller_x's Avatar
So I read through most of the stutter/sputter threads. I drove the car to New York for holidays. Approximately 500km from my place. So I have this annoying sputter at cruise doing about 100km/h (60mph) the colder (-20F / -30C) it gets the worse it gets. My AFRs are bouncing pretty good.(14 - 15.8) under wot my AFRs were good at 11.1
Not sure if I got bad got a couple tanks of bad gas or what.
The sputter went away on the way back but only two things changed.
It got warmer. 32F / 0C
I switched around my relays
The car has sat a lot over the last couple months due to military trips. And this was her first long drive in a bit.
Thoughts / ideas ... Suggestions?
Old Jan 4, 2013 | 09:22 PM
sgambino92's Avatar
different changes in altitude? is it tuned or stock?
Old Jan 4, 2013 | 09:28 PM
Miller_x's Avatar
I am tuned. On the same tune for a year. Only recently have had issues.
Elevation my have something to do with it. My place is 427ft above sea level. Lake placid is about 2000. But it was doing it the whole trip regardless.
Old Jan 4, 2013 | 09:42 PM
sgambino92's Avatar
and it only did it through ny?
Old Jan 4, 2013 | 09:49 PM
Miller_x's Avatar
It did it the whole trip but was most noticeable in Lake placid. But it was the coldest there as well.
Old Jan 4, 2013 | 10:01 PM
Buru_EvoX's Avatar
I get sputtering when I'm cruising around 50-60mph and very light on my throttle. Is that normal?
Old Jan 5, 2013 | 01:57 PM
Miller_x's Avatar
From the threads I've read it's pretty normal to have the occasional stumble especially in low rpms cruising. The two things that concerned me is that I am normally around 2800 rpm in 5th and it stutters. Normally under some load. At the same time though if I shift down at that rpm I am at 4000 rpm in 4 th it is very consistent when it's cold out. Is there some temp - wastegate correction I could adjust in openecu? To smooth it out or make less noticeable?
Old Jan 5, 2013 | 02:05 PM
meckert's Avatar
You let the car sit with gas in it for a few months and thats not good at all, you get varnish build up, things stick and in general fuel degradation. Drain the tank and refill and change your plugs-- Gas goes bad, so you can't just leave it and go. My .02--.
Old Jan 8, 2013 | 10:15 AM
SP33D FREAK's Avatar
yeah i agree with you. gas goes bad. but could it also be a bad fuel injector?
Old Jan 9, 2013 | 05:29 AM
Miller_x's Avatar
It very well could be. Or even one that may have plugged up a bit from sitting I have put a far bit of miles over the last 30 days and my driveability has improved.
I'm still on the stock pump and am tuned to about 360tq/370hp could this be hurting/hindering me?
papabeardoe
Jun 13, 2017 04:06 AM
Saint47
Feb 23, 2017 11:42 AM
Igaly1021
Nov 7, 2015 05:18 PM
godnf8
17
Jul 25, 2009 04:46 PM
thewyte1_2
Sep 20, 2007 08:01 PM
