Sputtering and Stuttering
Old May 25, 2017 | 01:41 PM
papabeardoe's Avatar
Ok so when im cruising around 3500rpms the cars starts sputtering until i push the clutch in and let it out. When its sputtering the AFRs go all the way lean. I just dont know whats going on ive changed the plugs.
Old May 25, 2017 | 04:27 PM
C130flyer's Avatar
are you on SD? if so your map sensor is bad
Old Jun 6, 2017 | 06:10 PM
No im not on sd.
Old Jun 6, 2017 | 07:28 PM
4G63_EVO's Avatar
Do a boost leak test
Old Jun 7, 2017 | 10:15 AM
Project_Broke's Avatar
Originally Posted by 4g63_evo
do a boost leak test
this
Old Jun 7, 2017 | 11:53 AM
ZOMGWRX's Avatar
Interesting...I had this happen to me and it turned out to be my coils were bad. I got some Spoolinup COP and haven't had that issue since. But I'd do a boost leak test like mentioned and I believe the IX's sputter every so often around 3k rpms especially in a higher gear going uphill.
Old Jun 7, 2017 | 04:37 PM
Did one before and fixed a few small leaks. Just installed a spoolin up cop this past weekend and its still sputtering. I'll do another boost leak test.
Old Jun 8, 2017 | 03:55 AM
Bad fuel? Did you fill up recently? Possibly clogged injector.
Old Jun 9, 2017 | 11:20 PM
mines5's Avatar
I experienced a similar situation , as soon as the car comes out of vacuum around 3-4k rpm it wud sputter badly. Checked everything , finally checked the injectors and wolla found the culprit. Changed to stock injectors for testing and all was good.
Old Jun 10, 2017 | 05:55 AM
The car is daily driven
Old Jun 13, 2017 | 04:06 AM
Alright, well your symptoms indicate lack of fuel during this period so throwing ideas out.
What kind of FP? Maybe it's starting to go. Possibly the MAF. Have you tried cleaning/swapping it? Could also be a tear between the MAF and turbo you may not use during a leak test.
CT9A PR
Oct 29, 2015 06:44 PM
SmurfZilla
Mar 9, 2010 05:28 AM
death1969
Sep 12, 2009 08:06 PM
nyrican
Aug 6, 2005 06:40 PM
EvoInSoCal
Jan 26, 2004 09:33 AM
