best headgaskets for 4g64evo
Old Mar 1, 2011 | 03:44 AM
evoyrrah's Avatar
hey guys....i done my headgasket(cometic) on my 2.4l and im wondering which one i should get now? hks? power enterprise?...im runnin about 34-35psi with the fpblack and about 500hp on mustang dyno vdr....i should also run the arp L19 headstuds??
any thoughts??
Old Mar 1, 2011 | 04:52 AM
Fast_Freddie's Avatar
Veteran: Navy
AMS, PE, or Cometic are the options you should be looking at...
Old Mar 1, 2011 | 08:41 PM
evoyrrah's Avatar
Bumpo
Old Mar 1, 2011 | 09:31 PM
RSMike's Avatar
is his information not good enough?
Old Mar 1, 2011 | 11:21 PM
evoyrrah's Avatar
just trying to see if anyone knows anything......ams dont advertize a 4g64 gasket at 87.5 my cometic blew so dont wanna go there and i havnt really heard about powerenterprize....just trying to work out a good head gasket and stud combo
Old Mar 1, 2011 | 11:41 PM
RSMike's Avatar
like he said.
I'm pretty sure JohnBradley at ER uses Cometic gaskets with L19 headstuds, like him a PM.
Old Mar 2, 2011 | 08:07 AM
JohnBradley's Avatar
Its all about the block and head prep prior to the headgasket. 87.5mm will be a hard one to seal no matter what. For that I'd look into the Titan SCE copper gasket.
aaron
Old Mar 2, 2011 | 08:16 AM
BoostINurI's Avatar
No one has said Mitsubishi MLS yet...something I'm missing here?
Old Mar 2, 2011 | 08:20 AM
Yeah if you bore them (factory 4g63 MLS) out that thin there is no fire ring, the factory 4G64 gasket is only a 2 layer, and the PE seems to go away if it taps the rev limit too often. Sometimes it goes away without any reason and hangs the fire ring in the cylinder.
Old Mar 2, 2011 | 08:25 AM
BoostINurI's Avatar
Very nice ...Thanks for enlightening John!!
Old Mar 2, 2011 | 12:36 PM
evoyrrah's Avatar
aaron
should i oring the block or head john?
Old Mar 2, 2011 | 01:06 PM
n2oiroc's Avatar
I have a new 1.2mm x 87mm pe gasket if anyone is interested.
Old Mar 2, 2011 | 04:55 PM
I have done neither running at 38psi, nor did Mikey at 40psi with 10.5:1. Then again we are running an 86.6mm bore (mine) and an 87mm. I dont have any experience with the 87.5mm stuff....yet
Old Mar 2, 2011 | 04:57 PM
localtoys73's Avatar
what is the standard bore? 87mm?
Old Mar 2, 2011 | 05:14 PM
miragevo's Avatar
Veteran: Navy
4g64 standard bore is 86.5
SCE Gaskets makes the ICS Titan Head Gasket for Mitsubishi Evo and comes in an 87.3 bore. It has combustion o-rings and seals for the water jackets already built in.
http://www.scegaskets.com/ICS-Titan-...98857-1-2.html
