best headgaskets for 4g64evo
Yeah if you bore them (factory 4g63 MLS) out that thin there is no fire ring, the factory 4G64 gasket is only a 2 layer, and the PE seems to go away if it taps the rev limit too often. Sometimes it goes away without any reason and hangs the fire ring in the cylinder.
Do NOT go with PE. I would suggest AMS.
-Acree
yeh, this why i thought id ask....87.5mm bores, i knew i was asking for it....ill ring ams in the morning and see what they say, however, johnbradley says itll be machined too much and take out the fire ring?.....abit confused
its 165 shipped boss. my car is 100% fine and jms put over 1000 miles on it first then took it to they dyno to push it. again 100% fine. Mike@awd also uses ams hg in his 2.4 and guess what perfect no issues boss. just get this one and you will be golden
