0.20" over headgasket question
Old Feb 28, 2016 | 01:19 AM
roni4g63's Avatar
Hello all, I just pulled my motor today, going with a 2.3 stroker kit manely billet crank wiesco 1400hd manely i beams (possibly Carillo)
my question is, with a 0.20" overbore, I obviouslt cant use the oem hg(i think?) what headgasket is most reliable after oem? I am not worried about the price, i just want a great oem like seal but for a 0.20" over block. thanks
Old Feb 28, 2016 | 02:37 AM
3gturbo's Avatar
Power enterprise makes a nice mls as well as the felpro permatorque either of those will work great. Dont buy a cometic they are a lot harder to get to seal. .20 over is 86mm for the 2.0 or 87mm for a 2.4 block.
Old Feb 28, 2016 | 12:26 PM
BiFfMaN's Avatar
The stock head gasket is slightly above 86mm, or 3.385 inches when i did my measurement.
My stock block was Bored 0.20 over putting it at 85.42mm, or 3.366 inches
So i stuck with the Stock Evo 9 Head gasket.
If it is the First time your engine is getting a Overbore done, then you will be fine.
But as always its best to take a measurement prior AND Post Machining.
Old Feb 28, 2016 | 05:28 PM
roni4g63's Avatar
thanks for the reply guys, yes its the first time it's getting bored out, so i should be able to use the oem gasket, new obviously, thanks guys!
Old Feb 29, 2016 | 12:31 PM
BiFfMaN's Avatar
A lot of people do just fine with the stock Head Gasket
https://www.evolutionm.net/forums/ev...u-using-4.html
Old Feb 29, 2016 | 07:02 PM
Erik@MIL.SPEC's Avatar
OEM headgasket will work find on a .20 overbore. It's what I am using (Evo 9 MLS).
johnson81420
14
May 5, 2019 06:12 PM
johnson81420
Apr 21, 2012 09:37 AM
Peteypab2133
Future Lancer / Evo Models
31
Oct 5, 2007 06:03 AM
kf6ytc
May 15, 2006 07:39 PM
yoyoyoyoming
Aug 1, 2004 06:59 PM
