boost cut due to cold weather?
From what you have explained it definitely seems like a problem with the spark plugs. Check all 4 plugs and make sure they are all tightened. At first I would think a leak somewhere between MAF and the turbo. With the Evo's vented hood it's also possible for water to get into the spark plug cylinder. Believe it or not it happens. If everything wasnt tightened appropriately and all sealed up, that could be the problem. Let us know what you find out when you fix it!
Glad you were able to get her running. FYI good fresh plugs gaped properly with a good set of wires will pretty much run under water. Did you pull the plugs and take a look at them and check the gap?
JosRacing4G94T
May 3, 2017 10:58 AM
beatricevq
Apr 21, 2015 10:10 PM
