Transmission problem?? Pls help
Old Nov 4, 2016 | 02:28 AM
eddy5201314's Avatar
hi I have an evo9 and the gearbox is very hard to change gear when it's cold from first gear to second gear, it's only when the car cold once it's up to temperature it shift fine. The feeling is like change from first gear to scoundrel gear the whole gearknob is shaking and I can't get into secound gear. I don't know how to describe it, I think it's call transmission slipping? It's only happens when the car is cold and only from first gear to second gear.
has anyone had this problem and how to get it fix?
Old Nov 4, 2016 | 03:04 AM
It's like grinding when changing from first gear to second gear.
Old Nov 4, 2016 | 07:28 AM
llDemonll's Avatar
have your clutch pedal adjusted
otherwise could be a worn clutch but that would have more symptoms
Old Nov 4, 2016 | 02:14 PM
yeah the clutch friction point is very high, can I adjust the pedal to lower position? How to do it?
eddy5201314
Dec 8, 2016 09:19 AM
CrackerJackToy
Sep 4, 2007 02:05 PM
EVILutionVIII
Aug 12, 2007 11:38 AM
evo racing
Jun 3, 2006 08:36 PM
evo8silver
Feb 6, 2005 06:01 PM
