Stock HID problem...pls help
Old Jan 9, 2006 | 03:26 PM
evo racing's Avatar
Its been a problem lately... k well when i turn on my HIDs the right headlight is moving up and down like im adjusting it! but im not...the left headlight unit is perfectly fine...i have to turn the adjustment to 4 then back to 1 in order for it to stop...but now my right headlight has a lower beam then the left...do u think its a mad motor on the HIDs adjustment thing?
Old Jan 17, 2006 | 05:23 PM
silver_evo's Avatar
Mine has done that also, like if i set it for 4 they move then stop then move up and down and up and down until i move the switch again, i think its a problem with the servo-motor or the programming in the headlight control unit, not too sure. do the headlights move together right, or does that right one just stay low.
Old Jan 17, 2006 | 05:34 PM
Evo VIII's Avatar
I always thought that the adjustment feature was only for the 2005 SSL package evo's. Hmm, you learn something new every day.
Old Jan 17, 2006 | 06:41 PM
EvoRicer's Avatar
Most of the 2003s came with SSL already off the lot...didnt have to add it on. My headlight doesnt move, but my left side is lower than the right. I tried adjusting it, but it wont move...
Old Jan 17, 2006 | 07:24 PM
Evo VIII's Avatar
My left is lower than my right also, is that normal?
Old Jan 17, 2006 | 07:36 PM
CDO's Avatar
CDO
That is exactly what I had and how I would stop it from going up and down. Dealer replaced the whole right headlight assembly to fix it. (Under warranty)
According to the work order I have it's the internal adjuster motor that was broken.
Old Jan 18, 2006 | 08:29 AM
evo racing's Avatar
whoa thats exactly whats happening to mine... so the many times its done that, the left side headlight is shining higher than the right which is bad for on coming traffic...ehhh so theyll replace it?
Old Jan 18, 2006 | 08:33 AM
NoTec's Avatar
uh oh! I smell a RECALL brewing.
Old Jan 18, 2006 | 08:34 AM
elhalisf's Avatar
check the ground wire on the passenger side, beside the front of the fender.
Old Jan 18, 2006 | 08:37 AM
CRVdrftR05's Avatar
no IXs with this problem?
Old Jan 18, 2006 | 08:40 AM
oak2207's Avatar
I have an '03 and haven't run into this problem. I did however do the manual adjust on 'em to make 'em higher up. Have you guys that are having the problem done this?
Old Jan 18, 2006 | 08:43 AM
4rcd6's Avatar
Mines been fine on my 03.
05's have this option also?? I thought they didnt cause of the no HID's on 05+. Hmm maybe the projectors have adjusters.... thats interesting
Old Jan 18, 2006 | 08:44 AM
GPTourer's Avatar
Well, no. There was no SSL package for '03s, just the S as in sunroof was an option, but no leather or upgraded sound system is available. But all '03's have HIDs.
Old Jan 18, 2006 | 08:46 AM
lilman8403's Avatar
Headlight problem
This sounds like it might be a switch problem. Test the leads from the switch while this is happening and then again when it is not, or leave your lights where you want them and unplug the switch.
Old Jan 18, 2006 | 08:49 AM
4rcd6's Avatar
best bet is to take it to the dealer if its under warranty. Usually there wont be a problem since you havent upgraded the headlights lol
