Installing an exedy twin disk rebuild?
Old Mar 4, 2011 | 01:38 PM
tim85851's Avatar
Ok so i ordered my rebuild for my twin disk...
But im installing it with my friends at their shop...and was wondering what else do i need?
By this im meaning do i need parts that arent from exedy? or can i just drop the tranny and put the new rebuild in and be done with it? (im hoping thats the case here)...
also wondering after the rebuild is in...is there like a break in period? or can it be driven?
thanks!
Old Mar 4, 2011 | 01:51 PM
wizzo 8's Avatar
500 miles of normal driving for break in
Old Mar 4, 2011 | 02:07 PM
tim85851's Avatar
ok thanks.
any input on the install?
Old Mar 4, 2011 | 02:20 PM
8UpUrV8's Avatar
You're going to need to resurface the flywheel and have the legs machines down as well (any machine shop should already know this and tell you the same thing.
You're intermediate plates will need to be checked for straightness and replaced if not straight.
Both my plates were warped and needed replacing... around 500 bucks from MAP.
I will not be rebuilding this clutch again, too damn expensive. Clutch cost 1400 and rebuild was 1050... wtf lol.
My input on the install, if you're doing it on a lift it shouldn't be too bad.
I did mine in my garage and ended up removing the subframe to make getting the tranny in and out easier.
Old Mar 4, 2011 | 02:42 PM
tim85851's Avatar
your rebuild was that much?
did you talk to adam at map? because i got a wayyy better deal than that... :/
Old Mar 4, 2011 | 03:40 PM
cfdfireman1's Avatar
new TOB
Old Mar 4, 2011 | 04:38 PM
tim85851's Avatar
a new throw out bearing? is that necessary?
can anyone back this up?
i want to be positive since i have to order before next weekend...and make sure i get it by saturday...
Old Mar 4, 2011 | 04:43 PM
still*boostn's Avatar
its just one of those things you do. its cheap. easier now then later. unless it has less then 10k on it I would.
like building your stock 2L but reusing the water pump and oil pump cuz they "work", you can but thats retarded.
Old Mar 4, 2011 | 05:08 PM
wizzo 8's Avatar
Do the throwout bearing now. Its what $50 or something like that? If you get this new clutch in and find out a little later down the road the TOB is bad its just going to cost you more later because you will have to remove the trans again to replace it.
Old Mar 4, 2011 | 05:19 PM
tim85851's Avatar
ok...will order that then...
and whats with those wavy clips? do i need more of those?
Old Mar 4, 2011 | 05:28 PM
wizzo 8's Avatar
There are normally 2. I added an extra 1 but you really need one of these
https://secure.buschurracing.com/cat...3ae5e0ee14bcb2
Old Mar 4, 2011 | 07:56 PM
tim85851's Avatar
where would i get extra wavy clips?
Old Mar 5, 2011 | 10:17 AM
YMCMB's Avatar
i gave mine more like 800 miles for the break in period just wanted to be safe and have no problems down the road
Old Mar 8, 2011 | 12:49 PM
tim85851's Avatar
ill be sure to break it in with a minimum of a 500 mile break in.
i ordered my new throw-out bearing...
and looking into a clutch fork stop...i might try to make my own...but we'll see how that goes.
Old Mar 8, 2011 | 06:10 PM
wizzo 8's Avatar
I made my own. Took me a while to get all the dimensions correct but it works.
