A Warning about ACT clutches to eveyone
Old Mar 6, 2011 | 02:33 PM
  #31
mrdevo's Avatar
I put my act hdss on at 48,000 miles when I put meth on the car. I had mitsubishi put it on for me, charged a good amount but was worth it. The main mechanic did it and everything went well.
They resurfaced the stock flywheel for me and that was it. The meth kit has been off for 2 years now and the car has 105,000 miles. Not a single problem but I haven't even launched once. I get some chatter on decel on the highway but it never really bothered me much.
Old Mar 6, 2011 | 02:43 PM
  #32
skold's Avatar
tear tear i get like 10k per clutch
Old Mar 6, 2011 | 04:08 PM
  #33
MJ23FE's Avatar
Originally Posted by SwishaSweet
Im not going to change my own clutch on the ground in my dirt driveway. The last 3 roads to even get to where I live are all gravel. And yeah shop rate is a ton of money when you have the only evo around and you have to tell the mechanics about things like bleeding the ACD pump and all that.
Old Mar 6, 2011 | 04:19 PM
  #34
05evoGSR's Avatar
I'll give a thumbs up to the ACT clutch and a thumbs down to the OP. 40k+ on mine and no issues.
Old Mar 6, 2011 | 04:26 PM
  #35
bigben's Avatar
I've put 61k on my HDSS, but the clutch was on the car when I got it, so it's seen more miles than that.
Old Mar 6, 2011 | 04:29 PM
  #36
CAD EVO's Avatar
This thread should be a warning about TOB .
Old Mar 6, 2011 | 04:33 PM
  #37
fugiwara's Avatar
exactly! Before I put in my ACT clutch I've done so many research about it. OEM TOB is the way to go.
Old Mar 6, 2011 | 04:39 PM
  #38
Danner's Avatar
No complaints from me, my ACT clutch works wonderfully.
Old Mar 6, 2011 | 04:56 PM
  #39
playmajohn's Avatar
I'm in the same boat. Same clutch and I used ACT's TOB.
Now I have to pull my tranny out too..
I'm just scared when I get the tranny out, I wont be able to seperate the TOB from the clutch. I wasn't able to seperate it on my last clutch I simply removed it from the flywheel.
Anyone successfully taken off the TOB by wedging a flathead and turning?
Old Mar 6, 2011 | 05:00 PM
  #40
JohnDoe1984's Avatar
I had no problems getting the clip to release the TOB. Follow the directions at
http://www.evomoto.com/tech_articles..._article_id=27
Just use the fork to push the whole assembly together then use the screwdriver to cause the clip to come out at the same time as the TOB. Do it slowly in more than 1 spot and it pops right out.
Old Mar 6, 2011 | 05:29 PM
  #41
C6C6CH3vo's Avatar
OEM clutch TOB and pressure plate done by yourself will cost you less than $300. Resurface flywheel yourself with sandpaper and some kind of improvised rotating assembly. Will hold well over 400whp for years if you dont launch
Old Mar 6, 2011 | 05:56 PM
  #42
RSMike's Avatar
wow...
and i thought i was gash...
Old Mar 6, 2011 | 08:55 PM
  #43
evo8john's Avatar
Lol please delete this thread mods... I have been running an HDSS for over 40k with well over 350 wtq with 0 issues. TOB, as stated above, is a wear item and this could be an install issue from an inexperienced shop.
To the OP... Take it to someone that knows what they are doing next time and save yourself a huge headache and a few hundred bucks.
Old Mar 7, 2011 | 12:08 AM
  #44
Saskatchawhat's Avatar
This thread is full of sillyness an nonsense
Old Mar 7, 2011 | 01:01 AM
  #45
riceball777's Avatar
i have this clutch and it been great for the past 30k miles i have had it
i have a full race gt35r setup and it hold all the power with no problems.
