Transmission help, just rebuilt now no 5 or rev
Old Mar 14, 2011 | 04:33 PM
elhalisf's Avatar
Originally Posted by dsmcrazyspiff
You cant use a evo 9 input with a 03 evo 5th gear.. 03 5th gear has shorter splines that is your problem.. You will need to replace it with a newer 5th p/n MN 107624
only the early 03 transmissions have this issue, so this situation does not apply to all 03 transmissions.
Old Mar 15, 2011 | 05:37 AM
Boostin4life's Avatar
Well there is a spline difference, I ordered p/n MN 107624 for the 5th gear. Is this gear going to work with my evo 8 other 5th gear?
Old Mar 15, 2011 | 09:19 AM
elhalisf's Avatar
yes it will work. you might have trouble fitting a #9 washer, so you might have to hammer it in or grind it down.
Old Mar 15, 2011 | 10:11 AM
That's good news then, I bought extra washers the first time I went. Also have #8 and #6 so I hope outa the three one will be what I need
Old Mar 18, 2011 | 06:27 PM
Evo back together and runs great so far! Loving the car as always!
Old Mar 21, 2011 | 10:02 AM
dsmcrazyspiff's Avatar
Good to hear....
Charlie-Y
May 21, 2011 08:57 AM
pettyboy69
Dec 18, 2010 01:30 PM
Evo3573
17
Nov 14, 2010 09:47 PM
elijahcole92
17
Oct 19, 2009 11:46 AM
Tractionlimit
14
May 27, 2009 07:26 PM
