Anyone runnin a catchcan setup straight to the can only?
My friend was suggesting I can run lines from valvecover straight to a catchcan and have no returns. Can has to have a filter.
hell i broke the fitting off the valve cover and for nearly a month i ran with out anything... never dripped or left residue...
i have also seen a fella run a fuel filter it came off the valve cover to a lil cup thing with a filter on the other end... when he wanted to clean it he took it off and rinsed it with hot water the oposite direction.... clever if you ask me... but i'll stick to my weapon R
its the only way i would run it. if you route it to the turbo inlet, it will likely coat everything from the inlet all the way to your intake valves with oil after some time. no thanks.
FS[MidWest]: Saikou Michi dual catchcan with lines
tsidrift1
Jan 15, 2016 07:27 AM
Imhere4you2NV
Jan 3, 2011 04:02 PM
