Post your Exhaust db using phone & free app
So I just did a compare of a Omega HHSL1 sound measuring device vs. my phone running the free android boy decibel meter app.
California law calls for measuring 20" away from the exhaust tip between 3k-5k. I just performed a 3k rev check.
--------------******** Outside ********
--------------------Omega HHSL1-----Phone
--------------------db-C / db-A---------db-A
1200rpm---------108 / 86 ----------- 93
3000rpm---------110 / 93 ---------- 96
#### not sure why my phones outside 3k value is different than the other day??
----******** Inside w-windows closed********
1200rpm-------86-94 / 62 ----------- 60
3000rpm---------- 86 / 71 ---------- 72
inside cabin #'s are pretty close to each other when measuring in db-A
From my thread: here we go again quiet cat back clarification needed
2005 Evo VIII
HKS 272/272, AMS GT35R
GTSpec Headers, Perrin 3" downpipe, CBE, HFC.
--------------------Phone
--------------------db-A
1200rpm---------93 (distance 20')
3000rpm---------no data (no second person)
1200rpm---------73
3000rpm---------82
EDIT: HOLY ****! I just saw that your distance was 20" as in INCHES. I didn't read this post before I went out and measured... mine was 93 db at 20 FEET.
So from seeing these... It's pretty evident that my car is as loud as I think it is. I started it this morning and came back in to let it warm up, and when it idled down, the dishes were rattling in the cabinets.
2005 Evo VIII
1200rpm---------73
3000rpm---------82
I'll have to check this app out.
Way way back when at a drag race they had an audio contest going on and had a contest to see who had the loudest car. I placed 2nd at 137 dB in my 1994 Mazda MX6 V6. My buddy won at 141 dB in his Integra GSR. I think they measured from the same distance. I don't even want to know how loud my EVO is.
Started as an eBay tbe. I added a 7" round muffler to fit in the test pipe spot. I also added a 1ft 4" round resonator between that muffler and the rear one. Pretty quiet I think
I'm running a 2.3 AMS stroker kit, 4R cams, headwork, Peakboost GT35R, and tons of other supporting mods:
Exhaust setup: downpipe, testpipe w/ boost actuated cut out and stock catback.
Here is the cutout I'm using: http://www.spracingonline.com/store/...ctivated_/3673
Using the phone app my db readings were at 20 inches were:
78 db at idle
80 db at 3500 rpm
70 db in cab cruising at 3000 rpms.
78 db at idle
80 db at 3500 rpm
I'd like to see the db reading under load at 3k rpm
Buschur Turboback with small magnaflow and SD rear.
Inside with the windows up:
idle @ 1100= 78db
Outside 20" from muffler
idle @ 1100= 96db
The car wasn't at its loudest tonight and I didn't have a second hand to do a 3500rpm test.
idle @ 1100= 78db
idle @ 1100= 96db
No, the oem muffler is not modded. The way I look at is I spend 95% of the time cruising, so why have an exhaust system made for just 5% of my time at WOT.
The cutout starts to open at around 5 psi and is fully open at 11 psi. I really like this setup above anything else I have tried or seen.
Next time I'm out doing WOT pulls I'll take some readings. It definately growls when the cutout is open.
man... i am confused.
i am definately considering a 3" exh w/qtp near the oem muffler.......qtp triggered off of tps or boost
