Car wont go into gear
Old Mar 10, 2011 | 01:59 PM
keevo54's Avatar
Going home today I punched it in first and put the clutch in to go into second. Car would not go into second. If I push the clutch pedal down it goes down and comes back up. I put the car in nuetral and coasted off the road. I started the car in first and it made a terrible schreeching noise. I got it moving and shifted without the clutch to get it home. If I pushed the clutch in and tried to go into gear with the car started it would lock me out and make a terrible noise.
Anyone have any ideas on what this could be?
Old Mar 10, 2011 | 03:32 PM
MitsuJDM's Avatar
Sounds like something up with the clutch. If you can shift without the clutch, then chances re nothing is wrong with the trans. IF using the clutch to shift cause problems, something is wrong with it. What, I have no idea, but it's a starting point.
Old Mar 10, 2011 | 04:53 PM
PromDizzle's Avatar
I had this problem severely 4 months prior to my clutch being completely destroyed. i bled the clutch with new fluid, thinking the old fluid had gotten to hot and boiled, possibly leaving an air bubble in the line. worked great, but started again weeks later, got so bad i started in first to drive next door to the shop and got a huge bang, everything worked and looked fine so i left it. figured when the clutch went we'd look at it, to my best knowledge it was something with the clutch fork, hard to tell with it all being so deep in the engine, but best figure it out sooner than later.
Old Mar 10, 2011 | 11:30 PM
ranz's Avatar
are you sure its always the case? because am having a problem shifting into 4th gear only in those cases(4th-5th-4th or 4th-neutral-4th). everything else works perfectly even when car is on idle or off all gears will go smoothly!
*i just installed the new QM 7.25 twin clutch and a rebuild kit for the trans.
Old Mar 10, 2011 | 11:39 PM
panem's Avatar
your syncro's have gone bad. if you can put your car into all the gears with your car off and then turn your car and try. if doesnt go into gear while your car is on then your syncro's is the problem.
Old Mar 11, 2011 | 08:00 AM
ranz's Avatar
synchros are new i just did the rebuild!u think it can be synchro although i can shift from 3rd to 4th smoothly?
Old Mar 12, 2011 | 04:32 AM
keevo54's Avatar
bump for more advice
Old Mar 12, 2011 | 08:55 AM
barneyb's Avatar
I have to disagree. How can all the synchronizers go bad at once? This is a good clutch test.
Old Mar 12, 2011 | 12:00 PM
playmajohn's Avatar
My car is in the garage I'm about to pull the tranny I am having the exact problems as you I suspect it is my throw out bearing but only time will tell. Check my posts for more info
Old Mar 12, 2011 | 12:13 PM
loffiekadaffi's Avatar
I just went through this. I had an Exedy triple disk and the clutch pack had come apart from the fly wheel because three bolts had either come loose or were broke. I ended up replacing the clutch and fly wheel.
Old Mar 14, 2011 | 04:14 AM
keevo54's Avatar
I'm afraid thats what happened to me. Anyone have any ideas on something that might be an easy fix?
Old Mar 16, 2011 | 12:48 PM
keevo54's Avatar
Any one else experienced this?
Old Mar 19, 2011 | 10:46 AM
playmajohn's Avatar
your car still down?
Anyone have this problem and ended up being the master cylinder?
Welcome2GoodBur
May 20, 2016 12:54 PM
rartist
Aug 11, 2010 06:21 AM
Tek3Evo
Aug 14, 2008 01:25 PM
Pure Playaer
26
Dec 25, 2006 10:11 PM
smokedmustang
23
May 9, 2006 09:40 AM
